First 8 characters not displaying properly
Hi guys. I've been working on a project of a smart room. Using a Arduino Mega, a 20x4 LCD Diplay, with some sensors and stuff. But when I woke up today and started working on my project, I noticed that the first 8 characters of the first 2 lines aren't showing up properly. I tried using a Arduino Uno, checked all cables and connections and also tried a different code. But the problem stills there. I let this display on for like 2 or 3 days for testing, and today that showed up. I bought this display on DealExtreme for 10 bucks, 3 years ago. Maybe my display is dying? That is the display: http://www.dx.com/pt/p/3-1-2004a-20x4-character-lcd-module-display-168593#.VvZ7b8orKUk
Here are some pics that I took of the display and connections:
OK, the four "blobs" on the board correspond to four quarters of the display. One, curiously enough the "master", has failed.
Tough.
Oh! You got the message about the capacitor on pins 1 and 2. Impressive!
Paul__B:
Tough.
So guess that I'll have to buy a new display. Right?
Cannot see any of the images.
Paul__B must be using a browser I am not, because I cannot see them period. They must belong to your private Google account, because I see gibberish about googlecontent ...
I get no images either.
When I look at the 'Image location' I get https://lh3.googleusercontent.com/ followed by several hundred alphanumeric characters.
From the description alone it is evident that the HD44780U controller is defective or one or more of the traces between that blob (the biggest one) and the display is damaged.
Don
ieee488:
Try here:
gabrielhowat:
Try here:
https://goo.gl/photos/Kfki7CTJ1ag1yjpX9
I see one photo. It shows two connectors on the LCD display backplane.
Are there more photos?
ieee488:
Oooook... That's weird. There's 4 photos on the album.
Try that: http://postimg.org/gallery/1srp326ge/
Use a decent image host if you need help.
Not some crappy one that requires you to be logged in to view images.
Believe it or not, not every one is logged in at google.
Ok, now it's so much weird.
Learn to post links also!!
Regards,
Graham
ghlawrence2000:
https://www.youtube.com/watch?v=-nSiEGakfLk
Regards,
Graham
Oh, I thought that this was auto.
Didn't you look at your own post? Also - you can check the link to make sure it works before you post if you use the preview feature.
Don
Don,
The problem is that the "How to use the forum - please read" sticky at the top of EVERY thread is not obvious enough for some people!!?? ???
Regards,
Graham
gabrielhowat:
It looks like you may have a bad LCD display.
Just write a very simple sketch writing '0123456789ABCDEF' to each line of your display.
Then you will know.
Then you will know.
He already knows, from the very first reply. Most of the rest of the replies refer to the missing attachments.
Don
Hi.
From the pictures and the youtube link, some different problems are visible.
It's not just these first 2 rows that aren't as good as the rest of the display (the contrast setting seems to be incorrect).
You also have a power problem, as soon as you are switching on your LED strip, something usually described as weirdness (including you).
Make sure your Arduino and display get their own, stable supply, and put the LED strip on another supply.
Take your display, and turn it over.
You will see a few metal parts of the bezel protruding through the PCB.
These hold the bezel in place, putting some pressure on the glass, the rubber like "zebra" connector strips, and the PCB.
See if you can turn these metal tabs a bit (be careful), and adjust the pressure that way.
If you're lucky, you might solve the problem with the poor contrast.
floresta:
Don
I had and still have no clue what Paul__B meant, so pardon me for the redundancy.
----- OK, the four "blobs" on the board correspond to four quarters of the display. One, curiously enough the "master", has failed. ----
What are "blobs"?
Without seeing the attachments, I couldn't see the problem.
When I saw his photos, then I could give an opinion. And I can't be certain the original attachments which can't be seen are the same as the photos in his later links.
ieee488:
What are "blobs"?
Black blobs.
Hmmm. I saw the pictures on my other PC here, and on this one they are rubbish. :astonished:
Nope - gone here too! Useless hosting site.
Paul__B:
Black blobs.
It is too bad this forum doesn't allow the upload of images from our own hard drives.
That would solve the problem of needing a hosting site.
