first arduino project
Hi all,
I am new to microcontroller and arduino. But I noticed that I might be able to come up with a device to collect pressure, temperature, and velocity vector. Based on the simple search, I looked at "Using SPI to read a Barometric Pressure Sensor" and "ADXL3xx Accelerometer."
Based on the descriptions, I need 1) Arduino Board http://www.amazon.com/Arduino-UNO-board-DIP-ATmega328P/dp/B006H06TVG/ref=sr_1_2?ie=UTF8&qid=1420015500&sr=8-2&keywords=arduino
2) ADXL3xx Accelerometer http://www.amazon.com/SainSmart-ADXL335-Accelerometer-Breakout-Arduino/dp/B006J4G4FQ/ref=sr_1_1?ie=UTF8&qid=1420015560&sr=8-1&keywords=ADXL3xx+Accelerometer
http://www.amazon.com/RioRand-10DOF-L3G4200D-HMC5883L-Breakout-/dp/B00GONRN9I/ref=sr_1_1?ie=UTF8&qid=1420015614&sr=8-1&keywords=ADXL3
3) SCP1000 Pressure Sensor Breakout Board : Can't find this sensor
4) Breadboard or prototyping Board : ?? Does this come with package?
What would be the best way to get them without too much cost and would I need additional items to make it work?
Thanks,
Kihwan
As you are new to Arduino and I presume to electronics, I suggest you get familiar with the basics first. You do not state you're programming experience.
Weedpharma
Yes, I am new to microcontroller itself, including Arduino. I just completed the 1st round of Basic Stamp Discovery Kit from Parallax Inc. My programming experience is advanced, including linux/unix admin experience.
I don't see any problem in programming. I think I need to know what components I need to buy to make a complete, functional package to collect pressure, temperature, and velocity vector in a model airplane or model rocket.
Thanks,
Kihwan
This "RioRand-10DOF" breakout has already all the the components you need. It has a 3 axis gyroscope (L3G4200D), a 3 axis accelerometer (ADXL345), a 3 axis magnetometer (HMC5883L) and a barometer (BMP085). The barometer also includes a temperature sensor.
However I'd probably advise you to use a different breakout (no description, 25$). I used a breakout called gy80 some time ago and it worked pretty well. It should be available starting from 10$ and it has exactly the same components on it as the above-mentioned.
Furthermore I always prefer using I2C over SPI. I is slightly more difficult for the beginning, but I think if you have multiple devices it's better.
I think I have a library for those components on my computer which allows to get the data from all the sensor at once rather than having 4 different libraries reading out the code. In case you are interested, just write me a pm.
Thank you JoshuaJ,I will write you a message sometime tomorrow. I gotto go to work now. Thanks for help!
Kihwan
