Note:
The input resistance to a FET is infinite.
It does have capacitance, gate to GND, see data sheet.R45 is there to protect the Arduino output.
i.e. it limits the output current to a safe level while the FET input capacitance charges.
If the only reason for R45 is to protect the Arduino, then wouldn't a larger resistance value be better? Or are you stating that, while this is true, 1K is still overkill?
Looking at your schematic, my main confusion comes from the 12 Volt and 5 Volts supplies you have at the top. I understand the 12 Volt would be coming from the wall and to the motors (as well as the voltage regulator). But then if I follow the output of the voltage regulator it looks like you have another 5 Volt source attached to that wire?
Is the "+5V" you have marked at the top simply stating that this wire is now 5 volts because of the voltage regulator and does NOT represent a separate voltage source?
Continuing to follow the schematic it looks like you're powering the Arduino with input to Pin 5, but also taking from this pin to power the RTC? Am I reading this correct?
Once again, thanks for taking the time to answer these elementary questions, I've learned more about circuits from you and this project than the last month trying to research online.
Also, I looked into more accurate (and slightly more expensive) RTC's but I thought for my final purposes this would probably be unnecessary. In the end, I really just want the capability to check and dose a few times per day, having this happen at the perfect time isn't a primary concern. I hear the cheap RTC's probably lose 2 to 10 seconds per day.
If we go with 10 seconds per day, that's 3650 seconds per year. There's 3600 seconds in an hour which means the time is off about 1 hour every year.
While annoying, I think I can live with this for the decreased cost. I'm open to arguments if you think otherwise though.
Thanks!
-Chase
P.S. - Thanks for the clarification on the 12 volt schematic. That's exactly the kind of thing I want to know so I can do things the right way.
