Soooo I finally decided to try writing my own code. It is for a BMP280.
The goal is to have the BMP 280 print the pressure and altitude on a I2C 16*2 screen that has a I2C adapter. In theory it will run from an Arduino Nano. The code is below. I honestly don't know enough about error codes to know what to do with them... or how to fix them.
...and I'm sure there will be many as this is the first time I've tried to write code myself.
#include <LiquidCrystal_I2C.h> //Libraries for the screen and BMP280
#include <Adafruit_BMP280.h>
LiquidCrystal_I2C lcd(0x27, 16, 2); // I2C address 0x27, 16 column and 2 rows
Adafruit_BMP280 begin(); // initialize the sensor
lcd.init(); // initialize the lcd
lcd.backlight(); // open the backlight
delay(2000); // wait a few seconds between measurements
float T = bmp.readTemperature()*9/5 + 32; //Read temperature in C and conversion to F
float P = bmp.readPressure()/3386.39; //Read Pressure in Pa and conversion to inches of mercury
float A = bmp.readAltitude(1019.66)*3.28084; //Calculating the Altitude, the "1019.66" is the pressure in(hPa) at sea level
lcd.setCursor(0, 0); // start to print at the first row
lcd.print("Press: ");
lcd.print(P); // print the pressure
lcd.setCursor(0, 1); // start to print at the second row
lcd.print("Alt: ");
lcd.print(A); // print the altitude
lcd.print(" ft");
Look at the examples that come with the BMP library to see how to construct and initialize the bmp object. You are not doing it right.
For an I2C LCD display to work, the I2C address and the I2C backpack to LCD pin mapping must be correct. If the library default settings for either or both are not correct the LCD will not work. You can try to figure out the right pin mapping and use an I2C scanner to find the address, but if you install and use the hd44780 library that is done automatically by the library.
To install the hd44780 library. The hd44780 library is the best available for I2C LCDs. The library is available in the Library Manager. Go to Library Manager (in the IDE menus, Sketch, Include Libraries, Manage Libraries) and in the Topics dropdown choose Display and in the Filter your search box enter hd44780. Select and install the hd44780 library by Bill Perry.
The class that you want to use is the hd44780_I2Cexp class. There are examples to show how to use the library. The nice thing about the hd44780 library is that it will autodetect the I2C address and the I2C backpack to LCD pin mapping.
In the examples, there is a diagnostic sketch that will help us to help you if you still have trouble with the display. Run the diagnostic sketch and post the results.
ctowermpa:
Did you run code for BMP280 Sensor and LCD separately?
If not, please run separate code for sensor/LCD to make sure that there is nothing wrong with each sensors (such as wiring, coding).
