First byte jumbled up with the second byte
Hello there, I’m trying to read an array of bytes from my serial device after sending out a fixed command from Arduino. However, I noticed that the first byte returned has jumbled up with the second byte. Can someone please tell me what is wrong with my code?
char incoming[100];
byte command[] = {0xDD, 0x01, 0x05};
Serial.write(command, 3);
Serial.readBytes(incoming,100);
Serial.println(incoming[1],HEX);
Serial.println(incoming[2],HEX);
delay(100);
Expected first byte : 0x01
Expected second byte : 0xDD
Instead, when I read incoming[1], I got 0xFFFFFFDD. It seems that the first byte somehow has jumbled up with the second byte.
Please post your entire sketch, not just a snippet.
Sorry, this is the entire code.
char incoming[100];
delay(100);
Try byte incoming[100];
aarg:
Now the first byte is read as 0xDD (instead of 0xFFFFFFDD), the first byte 0x01 went missing.
ophirian:
I the first byte is read as 0xDD (instead of 0xFFFFFFDD), the first byte 0x01 went missing.
Again please, this time with meaning.
AWOL:
Now the first byte is read as 0xDD (instead of 0xFFFFFFDD), where 0xDD is supposed to be the second byte returned from my device.
Have a look at Serial Input Basics. Simple reliable ways to receive data.
...R
Array indices start at 0, not 1. You really haven't a clue what you got, because there is NO print() overload that PROPERLY handles printing an int in HEX format.
ophirian:
Sign extension.
Your byte is being treated as a signed rather than an unsigned quantity. So when it is padded out to 32 bits, the compiler adds the 1s so as to keep the numeric value (-34) the same.
To fix, either make 'incoming' an array of byte rather than an array of char, or cast it like so
Serial.println((byte)incoming[1],HEX);
Serial.println((byte)incoming[2],HEX);
