Just pulled up an old project and began serial data to help with some sanity checks.
It seems every time it is started or reset, the first character of the serial data is replaced with an ASCII character, in this case ‘S’ is constantly being replaced with ‘|’ (not capital i).
When this line is omitted from the sketch, ‘EL Online’ will print with the ASCII character ‘ÿ’ before it on the same line.
The sketch is very long so I’ve attached the setup. Has anyone any ideas?
pinMode(latchDevice, OUTPUT);
pinMode(indLED, OUTPUT);
pinMode(programSwitch, INPUT);
pinMode(pinClr, INPUT);
pinMode(clearLED, OUTPUT);
pinMode(appPWR, OUTPUT);
pinMode(resetButton, INPUT);
pinMode(10, OUTPUT);
Serial.println("Soter AMS build");
if (digitalRead(pinClr) == HIGH) {
for (int i = 0; i < 512; i++)
EEPROM.write(i, 0);
digitalWrite(clearLED, HIGH);
value = EEPROM.read(address);
myFile.close();
int stateOne = digitalRead(programSwitch);
int stateTwo = digitalRead(resetButton);
if (!SD.begin(4)) {
Serial.println("EL Failure");
return;
Serial.println("EL Online");
Ethernet.begin(mac, ip);
server.begin();
//Serial.print("Server Established ");
Serial.println(Ethernet.localIP());
Udp.begin(localPort);
if (stateOne == 0 && stateTwo == 0) {
b=0;
if (EEPROM.read (0) != 0xff) {
for (int i = 0; i < maximumPulses; ++i )
storedCode[i] = EEPROM.read (i);
if (value >= 1) {
digitalWrite(appPWR, HIGH);
Serial.println("SP Exists");
else {
digitalWrite(appPWR, LOW);
Serial.println("SP Empty");
delay(100);// added in v3 for delay in sensor rail 2 bug
Regards,
B
