sarouje:
I don't solder on a daily basis and I use a very cheap iron. See this post (Is this a good budget soldering iron? - #39 by sarouje - General Electronics - Arduino Forum) that shows the board I soldered.
i mean no offense but I've seen better joints.
arduinoaleman:
The ERSA TIP 260 (16 Watts) is perfect for soldering chips and resistors and other stuff to printed circuit boards.
I also use an ERSA 30S (30 Watts) for soldering when the tiny tip if the ERSA TIP 260 does not deliver enough power ot takes too long to heat up the stuff I want to solder.
If you have got the money you will not regret spending it on two different soldering irons.
If you do mostly electronic circuits, the TIP 260 will do the job.
My personal experience is restricted to ERSA products. I never had problems. There are other fine brands as well. Just do NOT buy the cheap stuff from China. Go for a well known brand, because one time you might need a replacement tip.
If you get used to your two irons (this does not take long) you will not need a temperature controlled station.
thanks but i doubt i will take 2 different irons, i would prefer only one good quality sold.iron
ElCaron:
Well, people will stone me, but this kind of soldering tips is all over the place internationally and fits multiple Chinese station. I filed a smaller chisel tip than usually available from them, have been using it for a few month now and am quite happy with it on my ZD-931ESD.
We have Ersa and Weller in the institute, so I also kind of know what I am missing. If this station breaks soonish, I would probably go for a brand product, but for now, it totally suits me.
i wasted enough good money on crappy chinese items. definetely no.
rpt007:
My 1980's Weller WTCP / Magnastat is still working; just exchanged maybe a dozen tips since then.
As said before, ERSA is ok, in my eyes Weller is still my favourite (I had a modern Ersa 2 years ago with temperature control - ok, but git back to my old Weller as it delivered a bit more power, at least I had the impression, when it came to critical solderings like big copper plane around the wire to be soldered; so now my son has got a modern Ersa for his 2-3 times soldering actions/year).
If you don't want to spend the money for a brand new Weller (today I would go with a WS 51 or WS 81), have a look at *bay; a lot of people who had enough money but then realized that they had no time to use it, sell their 2-3 years old Wellers for about half or 1/3 the new price.
If you want to go with ERSA or something else - get an iron with flexible silicon cord as already adviced before - makes everything easier, especially if you want use the iron often.
thanks now i've seen also the magnastat and I'm more confused than before
I've read many people had this item for decades too, and i've seen the price is not so bad.
I've seen on YT tutorials many expert people claims they use "big" chisel tip with SMD.
I'm wondering if it should be a good choice a Magnastat with a 2,4mm chisel tip at 370°C for both normal joints and SMD. what do you think ?
