Just trying out the IoT Cloud service and right away it doesn't compile.
I copied the thingProperties.h file right off the editor example. I'm using a generic We Mos D1 mini.
Error:
/usr/local/bin/arduino-cli compile --fqbn esp8266:esp8266:d1_mini:baud=921600,dbg=Disabled,eesz=4M,exception=disabled,ip=lm2f,lvl=None____,vt=flash,wipe=none,xtal=80 --libraries /home/builder/opt/libraries/latest --build-cache-path /tmp --output-dir /tmp/442686455/build --build-path /tmp/arduino-build-1180CF2A202A06C3B8FFD62343FD0293 /tmp/442686455/PoolTemp_V1
Using library arduino_debugutils_1_1_0 at version 1.1.0 in folder: /home/builder/opt/libraries/arduino_debugutils_1_1_0
Using library arduinomqttclient_0_1_5 at version 0.1.5 in folder: /home/builder/opt/libraries/arduinomqttclient_0_1_5
xtensa-lx106-elf-gcc: error: /tmp/arduino-build-1180CF2A202A06C3B8FFD62343FD0293/libraries/esp8266/esp8266.a: No such file or directory
Sample Code:
#include <dummy.h>
#include <Arduino.h>
#include <ESP8266WiFi.h>
//#include "fauxmoESP.h"
//#include <ESPAsyncTCP.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include "thingProperties.h"
#define SERIAL_BAUDRATE 115200
#define WIFI_SSID "********"
#define WIFI_PASS "*******"
#define ONE_WIRE_BUS 4
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
const char* ssid = "YOUR_WIFI_NAME";
const char* password = "YOUR_WIFI_PASS";
// the setup function runs once when you press reset or power the board
// initialize digital pin LED_BUILTIN as an output.
pinMode(LED_BUILTIN, OUTPUT);
// Initialize serial and wait for port to open:
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
// the loop function runs over and over again forever
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
ArduinoCloud.update();
