First line of output not shown in Serial Monitor
Continuing the discussion from Serial Monitor Not Working On Esp32(SOLVED):
Yes, it is later.
I tested:
  while(!Serial);
  Serial.print("start!");
  Serial.println("hello");
got 'hello' printed out, but never has 'start!' print out, why?
Thanks
You can try adding a delay before that print in case the problem is caused by the port not being initialized soon enough:
  while(!Serial);
Thanks.
Same result.
And the USB port lost connection after reset button pressed, need unplug and plug again to get connect.
Another phenomenon is that the serial monitor lost connection when the Baud Rate of communication be changed say from 9600 to 115200.
