First microcontroller project - TX - RX RS-485 via webserver
I've been wanting to play around with an Arduino for quite some time. Here's what I want to do... send and receive data via RS-485 and have a simple webpage gui that will be able to display the results and send the commands. I'm thinking of using an Arduino Mega 2560 with an ethernet shield. Does this sound feasable before I go and buy the wrong stuff?
Thanks
From what? To what?
What else is the Arduino going to be doing? The ethernet shield is not exactly plu-and-play on the Mega, which seems like overkill anyway. A UNO, on which the ethernet shield IS plug-and-play should be more than adequate. Unless there is more to the project than you have described.
I will be sending and receiving data from the 485 bus of my Jandy Aqualink pool controller. I want to create a webpage to control the pool. I have been given a parser for the Jandy protocol that was written in C. If you still think the UNO is better for this, I'll have to see if I can change my order, I got excited and hit the buy button prematurely :slight_smile:
Thanks again!
The UNO will be sufficient. Depending on which ethernet shield you are getting, it may play better with the UNO than the Mega. You could always order the UNO, too. Always nice to have a second Arduino sitting around, when you want to know "What if I...".
This is the ethernet shield I ordered by the way:
Sparkfun is closed on the weekends so Im not sure if Ill be able to change or add to my order.
I have .C code that runs in Linux and updates a webpage. How similar is this code to what I will need for the Arduino? I've attached the code if anyone wants to take a look.
Thanks
logserial.c (20.2 KB)
Not bad for my first project. I'm pleasantly surprised at how easy this little Arduino is to work with. I ordered this 485 breakout board from sparkfun; SparkFun Transceiver Breakout - RS-485 - BOB-10124 - SparkFun Electronics It uses an SP3485 chip to convert the TTL to rs485. Got it connected and it works well. I was also able to use the ethernet shield and a form method=get to create a webpage that controls and LED, reports the status on the webpage, and also send the status over a serial port and the 485 chip. I connected a 485 to usb adapter and was able to read the status to verify that it is all working. Here is the code if anyone is interested. Most of it is snippets of other code I found on the net. I just had to write a few lines.
#include <SPI.h>
#include <Client.h>
#include <Ethernet.h>
#include <Server.h>
#include <Udp.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 220 };			// ip in lan
byte gateway[] = { 192, 168, 1, 1 };			// internet access via router
byte subnet[] = { 255, 255, 255, 0 };                   //subnet mask
Server server(80);                                      //server port
int ledPin = 13;  // LED pin
String readString = String(30); //string for fetching data from address
boolean LEDON = false; //LED status flag
void setup(){
//start Ethernet
  Ethernet.begin(mac, ip, gateway, subnet);
//Set pin 13 to output
  pinMode(ledPin, OUTPUT);
//enable Serial1 datada print
  Serial1.begin(9600);
void loop(){
// Create a client connection
Client client = server.available();
  if (client) {
    while (client.connected()) {
   if (client.available()) {
    char c = client.read();
     //read char by char HTTP request
    if (readString.length() < 100)
        //store characters to string
        readString += c; //replaces readString.append(c);
        //output chars to Serial1 port
        Serial1.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          //dirty skip of "GET /favicon.ico HTTP/1.1"
          if (readString.indexOf("?") <0)
            //skip everything
          //lets check if LED should be lighted
        if(readString.indexOf("L=1") >0)//replaces if(readString.contains("L=1"))
             //led has to be turned ON
             digitalWrite(ledPin, HIGH);    // set the LED on
             LEDON = true;
           }else{
             //led has to be turned OFF
             digitalWrite(ledPin, LOW);    // set the LED OFF
             LEDON = false;
                 // now output HTML data starting with standart header
          client.println("Content-Type: text/html");
          client.println();
          //controlling led via checkbox
          client.println("<h1>LED control</h1>");
          //address will look like http://192.168.1.110/?L=1 when submited
          if (LEDON)
          client.println("<form method=get name=LED><input type=checkbox name=L value=0>LED
<input type=submit value=submit></form>");
          /* prints value as string in hexadecimal (base 16) */
          client.println("<form method=get name=LED><input type=checkbox name=L value=1>LED
          client.println("
          //printing LED status
          client.print("<font size='5'>LED status: ");
          if (LEDON)
              client.println("<font color='green' size='5'>ON");
              Serial.println("LED ON");
              client.println("<font color='grey' size='5'>OFF");
              Serial.println("LED OFF");
          client.println("</body></html>");
          //clearing string for next read
          readString="";
          //stopping client
          client.stop();
edit: Oh yeah, and I should add that I used this post to wire the rs485 chip: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1270227591
