The goal here is a bath water temperature alarm that buzzes when my water gets to the perfect temp (note, in the code below, the tempset is set for 90 so I can test code with monitor at dining room table without needing 114F water).
I’ve pasted here two sets of code. The first one “A” isn’t averaging the temps any more and when I look at the serial Monitor, it shows the same temperature continuously. It never changes. The buzzer just buzzes at its interval, but the program isn’t really monitoring my temperature any more; meaning when the temp goes above tempset it doesn’t turn off. And if the program begins with the thermocouple already reading above tempset, the buzzer doesn’t start when the temperature goes below. It’s stuck somewhere.
The second code “B” has a delay (which I’m trying to get rid of in “A”) in it and this one works fine; that is, it’s averaging and displaying the changing temps on the Monitor and the buzzer is buzzing when it’s supposed to.
I’m really stumped about how to get rid of that delay. I understand the Blind_without_delay principle and have applied to the buzzer, but why is it messing up the program now?
A
// code for bath water temperature alarm.
//include Max6675 library
#include "max6675.h"
//include RunningAverage library
#include "RunningAverage.h"
//Constants won't change
const int tempset = 90; //temp alarm setpoint
const int buzzerPin = 9; //buzzer pin
const int thermoDO = 4; //these are for MAX6675
const int thermoCS = 5;
const int thermoCLK = 6;
MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
const int vccPin = 3;
const int gndPin = 2;
//Variables will change:
int buzzerState = LOW; //buzzerState used to set the buzzer
unsigned long previousMillis = 0; // will store last time buzzer was updated
unsigned long previousMillis_Serial = 0; // will store last time sent to Serial Monitor
unsigned long interval = 750; // interval at which to buzz buzzer (milliseconds) for primary alarm
unsigned long interval_Serial = 1000; // interval at which to send to Serial Monitor
RunningAverage myRA(20); //Running Average
myRA.clr(); // explicitly start clean
// use Arduino pins
pinMode(buzzerPin, OUTPUT);
pinMode(vccPin, OUTPUT); digitalWrite(vccPin, HIGH);
pinMode(gndPin, OUTPUT); digitalWrite(gndPin, LOW);
// wait for MAX chip to stabilize
myRA.add(thermocouple.readFarenheit());
if(currentMillis - previousMillis_Serial > interval_Serial) {
// save the last send to Serial
previousMillis_Serial = currentMillis;
Serial.print("Running Average F = ");
Serial.println(myRA.avg());
//check average temp versus tempset and buzz alarm if so
if (myRA.avg() < tempset){
if(currentMillis - previousMillis > interval) {
// save the last time buzzed buzzer
// if the buzzer is off turn it on and vice-versa:
if (buzzerState == LOW)
buzzerState = HIGH;
buzzerState = LOW;
// set the buzzer with the buzzerState of the variable:
digitalWrite(buzzerPin, buzzerState);
buzzerState = LOW;
B
unsigned long interval = 1000; // interval at which to buzz buzzer (milliseconds) for primary alarm
// use Arduino pins
//check agerage temp versus tempset and buzz alarm if so
buzzerState = HIGH;
buzzerState = LOW;
buzzerState = LOW;
