I made a bath water temperature alarm to set off, when my water gets to the desired temp and so I dont have to keep monitoring it.
Technically it does what it's supposed to do, but Im using a "delay(1000)" in the code because I want to read the temperature to the serial port (9600 baud rate). However, I think this delay is messing up my buzzer timing; meaning, it buzzes at 1second intervals rather than the 500milliseconds that I've set in the "interval" constant.
Any clues on how to keep the baud rate, but get my buzzer to buzz at the interval I want?
Thanks!
Code below:
// code for bath water temperature alarm.
//include Max6675 library
#include "max6675.h"
//include RunningAverage library
#include "RunningAverage.h"
//Constants won't change
const int tempset = 114; //temp alarm setpoint
const int buzzerPin = 9; //buzzer pin
const int thermoDO = 4; //these are for MAX6675
const int thermoCS = 5;
const int thermoCLK = 6;
MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
const int vccPin = 3;
const int gndPin = 2;
//Variables will change:
int buzzerState = LOW; //buzzerState used to set the buzzer
long previousMillis = 0; // will store last time buzzer was updated
long interval = 500; // interval at which to buzz buzzer (milliseconds) for primary alarm
RunningAverage myRA(20); //Running Average
int samples = 0;
myRA.clr(); // explicitly start clean
// use Arduino pins
pinMode(buzzerPin, OUTPUT);
pinMode(vccPin, OUTPUT); digitalWrite(vccPin, HIGH);
pinMode(gndPin, OUTPUT); digitalWrite(gndPin, LOW);
// wait for MAX chip to stabilize
myRA.add(thermocouple.readFarenheit());
samples++;
Serial.print("Running Average F = ");
Serial.println(myRA.avg());
if (samples == 300)
samples = 0;
myRA.clr();
//check average temp versus tempset and buzz alarm if so
if (myRA.avg() < tempset){
if(currentMillis - previousMillis > interval) {
// save the last time buzzed buzzer
// if the buzzer is off turn it on and vice-versa:
if (buzzerState == LOW)
buzzerState = HIGH;
buzzerState = LOW;
// set the buzzer with the buzzerState of the variable:
digitalWrite(buzzerPin, buzzerState);
buzzerState = LOW;
