Hi Guys,
This is my first post to the forum, I'm RanSacked and I've just started my journey with Arduino programming. I've read through some programming tutorials but I've only just had a chance to build something as my Arduino has only just arrived.
I've got a couple of quick questions for my first project.
I'm wanting to create a prop bomb for an escape room type scenario where a group has to defuse a bomb before escaping (just to add pressure really) I've found a sketch that seems to fit closest to what I want it to do but there are a few things I'd like to change about it. On the sketch I've found, you enter the code first and then it starts timing down. I'd like it to start counting down as soon as a motion switch is activated (when the lid is opened) and for the password to be pre programmed into it.
My question is a two-parter;
A: For the motion switch, would I put the code for that somewhere in void setup or would it need to be part of the loop? Also, is there a way to disable to motion switch after it has activated the countdown (as I don't want it to keep starting the timer over and over)
B: To store the password into the sketch would I need to use a string variable for the password and the temp password being entered and would that work with the sketch below?
#include <Keypad.h>
#include <LiquidCrystal.h>
#include <Tone.h>
#define pound 14
Tone tone1;
int Scount = 12; // count seconds
int Mcount = 10; // count minutes
int Hcount = 0; // count hours
int DefuseTimer = 0; // set timer to 0
long secMillis = 0; // store last time for second add
long interval = 1000; // interval for seconds
char password[4]; // number of characters in our password
int currentLength = 0; //defines which number we are currently writing
int i = 0;
char entered[4];
int ledPin = 4; //red led
int ledPin2 = 3; //yellow led
int ledPin3 = 2; //green led
LiquidCrystal lcd(7,8,10,11,12,13); // the pins we use on the LCD
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
byte rowPins[ROWS] = {5, A5, A4, A2}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {A1, A0, A3}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
pinMode(ledPin, OUTPUT); // sets the digital pin as output
pinMode(ledPin2, OUTPUT); // sets the digital pin as output
pinMode(ledPin3, OUTPUT); // sets the digital pin as output
tone1.begin(9);
lcd.begin(16, 2);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Enter Code: ");
while (currentLength < 4)
lcd.setCursor(currentLength + 6, 1);
lcd.cursor();
char key = keypad.getKey();
key == NO_KEY;
if (key != NO_KEY)
if ((key != '*')&&(key != '#'))
lcd.print(key);
password[currentLength] = key;
currentLength++;
tone1.play(NOTE_C6, 200);
if (currentLength == 4)
lcd.noCursor();
lcd.clear();
lcd.home();
lcd.print("You've Entered: ");
lcd.setCursor(6,1);
lcd.print(password[0]);
lcd.print(password[1]);
lcd.print(password[2]);
lcd.print(password[3]);
tone1.play(NOTE_E6, 200);
delay(3000);
lcd.clear();
currentLength = 0;
timer();
char key2 = keypad.getKey(); // get the key
if (key2 == '*')
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Code: ");
timer();
if (key2 == '#')
currentLength = 0;
lcd.clear();
lcd.setCursor(0,0);
if (key2 != NO_KEY)
lcd.setCursor(currentLength + 7, 0);
lcd.cursor();
lcd.print(key2);
entered[currentLength] = key2;
currentLength++;
delay(100);
lcd.noCursor();
lcd.setCursor(currentLength + 6, 0);
lcd.print("*");
lcd.cursor();
if (entered[0] == password[0] && entered[1] == password[1] && entered[2] == password[2] && entered[3] == password[3])
lcd.noCursor();
lcd.clear();
lcd.home();
lcd.print("Bomb Defused");
currentLength = 0;
digitalWrite(ledPin3, HIGH);
delay(2500);
lcd.setCursor(0,1);
lcd.print("Reset the Bomb");
delay(1000000);
lcd.noCursor();
lcd.clear();
lcd.home();
lcd.print("Wrong Password!");
if (Hcount > 0)
Hcount = Hcount - 1;
if (Mcount > 0)
Mcount = Mcount - 59;
if (Scount > 0)
Scount = Scount - 59;
delay(1500);
currentLength = 0;
void timer()
Serial.print(Scount);
if (Hcount <= 0)
if ( Mcount < 0 )
lcd.noCursor();
lcd.clear();
lcd.home();
lcd.print("The Bomb Has ");
lcd.setCursor (0,1);
lcd.print("Exploded!");
while (Mcount < 0)
digitalWrite(ledPin, HIGH); // sets the LED on
tone1.play(NOTE_A2, 90);
delay(100);
digitalWrite(ledPin, LOW); // sets the LED off
delay(100);
digitalWrite(ledPin2, HIGH); // sets the LED on
delay(100);
digitalWrite(ledPin2, LOW); // sets the LED off
delay(100);
digitalWrite(ledPin3, HIGH); // sets the LED on
delay(100);
digitalWrite(ledPin3, LOW); // sets the LED off
delay(100);
lcd.setCursor (0,1); // sets cursor to 2nd line
lcd.print ("Timer:");
if (Hcount >= 10)
lcd.setCursor (7,1);
lcd.print (Hcount);
if (Hcount < 10)
lcd.write ("0");
lcd.setCursor (8,1);
lcd.print (Hcount);
lcd.print (":");
if (Mcount >= 10)
lcd.setCursor (10,1);
lcd.print (Mcount);
if (Mcount < 10)
lcd.write ("0");
lcd.setCursor (11,1);
lcd.print (Mcount);
lcd.print (":");
if (Scount >= 10)
lcd.setCursor (13,1);
lcd.print (Scount);
if (Scount < 10)
lcd.write ("0");
lcd.setCursor (14,1);
lcd.print (Scount);
if (Hcount <0)
Hcount = 0;
if (Mcount <0)
Hcount --;
Mcount = 59;
if (Scount <1) // if 60 do this operation
Mcount --; // add 1 to Mcount
Scount = 59; // reset Scount
if (Scount > 0) // do this oper. 59 times
if(currentMillis - secMillis > interval)
tone1.play(NOTE_G5, 200);
secMillis = currentMillis;
Scount --; // add 1 to Scount
delay(10); // waits for a second
//lcd.clear();
To me it seems that what I want from it is simpler than what this code is actually doing (whether that actually makes the coding simpler, I don't know), so I don't know if I can use this or if I'd have to start from scratch? Which is a bit daunting to me tbh.
Anyway, hope you guys can help. I've tried finding the answers myself but there is only so many hours you can spend trawling through tutorials and forums before you have to admit defeat and ask for help, haha.
Thanks again,
RanSacked
