First Project - Check for errors?
This is my first Arduino project as well electronics. The circuit is working just as I would like it to, but I was wondering if I have made any blatant wiring mistakes or inefficiencies.
int buttonPin = 12;
int ledPin1 =  13;
int ledPin2 =  11;
int ledPin3 =  10;
int ledPin4 =  9;
int motorPin1 = 2;
int motorPin2 = 8;
int motorPin3 = 7;
int motorPin4 = 6;
int motorPin5 = 5;
int motorPin6 = 4;
int motorPin7 = 3;
int buzzer = 1;
  pinMode(ledPin1, OUTPUT);  //Dev LED
  pinMode(ledPin2, OUTPUT);  //Blix LED
  pinMode(ledPin3, OUTPUT);  //Rinse LED
  pinMode(ledPin4, OUTPUT);  //Finish LED
  pinMode(buttonPin, INPUT); //Button
  pinMode(motorPin1, OUTPUT);  // setup Agitation Pump
  pinMode(motorPin2, OUTPUT);  // setup Dev IN Pump
  pinMode(motorPin3, OUTPUT);  // setup Dev OUT Pump
  pinMode(motorPin4, OUTPUT);  // setup Blix IN Pump
  pinMode(motorPin5, OUTPUT);  // setup Blix OUT Pump
  pinMode(motorPin6, OUTPUT);  // setup Rinse IN Pump
  pinMode(motorPin7, OUTPUT);  // setup Rinse OUT Pump
  pinMode(buzzer, OUTPUT); // Set buzzer
  while (digitalRead(buttonPin) == HIGH) {
    //Dev
    digitalWrite(ledPin1, HIGH);  //Turn on Dev Process Led
    analogWrite(motorPin2, 200);  //Dev IN Pump run for 3 seconds
  	delay(3000);
  	analogWrite(motorPin2, 0);
    delay(3000);				//Start Process Timer
    analogWrite(motorPin1, 200);  //Agitate for 3 Seconds
  	delay(3000);
  	analogWrite(motorPin1, 0);
    delay(3000);				//Continue Process Timer
    analogWrite(motorPin3, 200);  //Dev OUT Pump run for 3 seconds
  	delay(3000);
  	analogWrite(motorPin3, 0);
    digitalWrite(ledPin1, LOW);  //End Dev Process LED
    //BLIX
     digitalWrite(ledPin2, HIGH);  //Turn on Blix Process Led
    analogWrite(motorPin4, 200);  //Blix IN Pump run for 3 seconds
  	delay(3000);
  	analogWrite(motorPin4, 0);
  	delay(3000);
    analogWrite(motorPin5, 200);  //Blix OUT Pump run for 3 seconds
  	delay(3000);
  	analogWrite(motorPin5, 0);
    digitalWrite(ledPin2, LOW);  //End Blix Process LED
    //RINSE
     digitalWrite(ledPin3, HIGH);  //Turn on Rinse Process Led
    analogWrite(motorPin6, 200);  //Rinse IN Pump run for 3 seconds
  	delay(3000);
  	analogWrite(motorPin6, 0);
  	delay(3000);
    analogWrite(motorPin7, 200);  //Rinse OUT Pump run for 3 seconds
  	delay(3000);
  	analogWrite(motorPin7, 0);
    digitalWrite(ledPin3, LOW);  //End Rinse Process LED
    //Finished!
    digitalWrite(ledPin4, HIGH);  //Turn on Finished Led
    tone(buzzer, 1000); // Send 1KHz sound signal...
  	delay(500);        // ...for 1 sec
  	noTone(buzzer);     // Stop sound...
  	delay(1000);        // ...for 1sec
In your case, you might be able to get away with using the delay() function, but in general, it is not good to use (it is a blocking loop function). Google "blink without delay".
You could also use a while or for loop to do the pinMode() setup provided either all of the pins are consecutive or all pin numbers are part of an array. Let me know if that's not clear.
It might be overkill, but you could use debouncing on your pushbutton.
You could also use a single function for turning on a given motor, running for 3 sec and then turning off. The motor pin would be the argument to the function. That way, you could just make one function call per motor instead of rewriting those three lines every time you want to turn on and off a given motor.
Power_Broker:
Can you help with this part? I am running into troubles with the motorpin as the argument.
I can't seem to get this to work, I get this error:
45:15: error: 'motorpin2' was not declared in this scope
int buttonPin = 12;
int ledPin1 =  13;
int ledPin2 =  11;
int ledPin3 =  10;
int ledPin4 =  9;
int motorPin1 = 2;
int motorPin2 = 8;
int motorPin3 = 7;
int motorPin4 = 6;
int motorPin5 = 5;
int motorPin6 = 4;
int motorPin7 = 3;
int buzzer = 1;
    //Dev
    pumpINfxn(motorpin2);
    agitate();					//Agitate Function
  	delay(3000);
    //BLIX
  	delay(3000);
    agitate();
  	delay(3000);
    //RINSE
  	delay(3000);
    agitate();
  	delay(3000);
    //Finished!
  //Functions
  void agitate(){
  	delay(3000);
 void pumpINfxn(char pump) {
    analogWrite(pump, 200);  //Run Pump for 3 seconds
  	delay(3000);
  	analogWrite(pump, 0);
Got it!
int buttonPin = 12;
int ledPin1 =  13;
int ledPin2 =  11;
int ledPin3 =  10;
int ledPin4 =  9;
int motorPin1 = 2;
int motorPin2 = 8;
int motorPin3 = 7;
int motorPin4 = 6;
int motorPin5 = 5;
int motorPin6 = 4;
int motorPin7 = 3;
int buzzer = 1;
    //Dev
    pumpINfxn(motorPin2);		  //Dev IN Pump run for 3 seconds
    agitatefxn();					 //Agitate Function
    pumpOUTfxn(motorPin3);		 //Dev OUT Pump run for 3 seconds
    //BLIX
    pumpINfxn(motorPin4);		  //BLIX IN Pump run for 3 seconds
    agitatefnx();
    pumpOUTfxn(motorPin5);		 //Bix OUT Pump run for 3 seconds
    //RINSE
    pumpINfxn(motorPin6);	      //Rinse IN Pump run for 3 seconds
    agitatefnx();
    pumpOUTfxn(motorPin7);		 //Rinse OUT Pump run for 3 seconds
    //Finished!
  //Functions
  void agitatefxn(){			 //Agitate for 3 Seconds
  	delay(3000);
 void pumpINfxn(char pump) {	//Run Pump IN for 3 seconds
  	delay(3000);
void pumpOUTfxn(char pump) {	//Run Pump OUT for 3 seconds
  	delay(3000);
Add 1000uF and 100nF decoupling on the motor power buses.
And, time to learn how to draw a proper schematic :wink:
Is this the correct placement of the decoupling caps?
You have 3 buses.
Each bus should have a large and small capacitor.
You might be ok with 470uF instead of the 1000uF.
This is for noisy filtering.
Sometimes you need a 100nF cap at the terminals of each motor.
Other times 100nF from each motor terminal to the metal housing of each motor.
int motorPin1 = 2;
int motorPin2 = 8;
int motorPin3 = 7;
int motorPin4 = 6;
int motorPin5 = 5;
int motorPin6 = 4;
int motorPin7 = 3;
If you are using a UNO, and you are analogwrite to pins 2 to 8, I think you will find that only pins 3,5,6 are capable of PWM.
Tom... :slight_smile:
