Thanks ReverseEMF. Yes, multimeter and can do dc volts just not much else.
Solid 3.29 dcv out of the 3v3 pin. It cycles high to low when I put the multimeter between output 3 and ground. The motor has yet to run on my project at all. Runs fine off 2 AA’s. it’s rated at 3.5v and 75mA.
At the moment, the motor is tomorrow’s problem. When I put the multimeter where the motor should be, I have zilch, nada and nought. ![]()
