First project - help with code and vibration motor
AThanks ReverseEMF. Yes, multimeter and can do dc volts just not much else.
Solid 3.29 dcv out of the 3v3 pin. It cycles high to low when I put the multimeter between output 3 and ground. The motor has yet to run on my project at all. Runs fine off 2 AA's. it's rated at 3.5v and 75mA.
At the moment, the motor is tomorrow's problem. When I put the multimeter where the motor should be, I have zilch, nada and nought. :relaxed:
