Hello,
I'm still working on my first project. I got the menu system working and I can communicate with the user through the 2x 16 LCD. I'm using a "Super Start Kit" Uno 3 Project from Elegoo.
Everything seems to be functioning as I want (except the LCD), I use Serial.print for development feedback. This is my first time I learn any coding so this seemed helpfull. Surely my code looks like a mess and there are better ways, feel free to give feedback on that. But, the issue is that the screen is really flickering.
When I use a refresh rate of 1 till 2000, it's Always acting funny when I look from certain angles.
I feel like this is some sort of power issue or such, should the LCD be powered separately?
If you would load the code, I did a / / on the 'startup' part. Felt pretty useless while creating.
Thanks for any feedback!
//Load and use pre-defined LCD system
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
//create integers used
int Status = 1;
int Refresh = 1;
int RandomNr;
int Position;
int Move;
int RedLed = 12;
int GreenLed = 11;
int Button1 = 2;
int Button2 = 3;
int ZeroSetting = 0;
int LCDLight = 6;
int MaxSetting = 0;
int RandomMode = 0;
int MinRandom = 1000;
int MaxRandom = 4000;
int BState1 = 0;
int BState2 = 0;
int MenuPos = 0;
int ScreenMls;
int ScreenRefresh = 0;
const int ScreenRefreshInterval = 70;
unsigned long PreviousMls = 0;
const long Interval = 2000;
const long IntervalButton = 600;
String vers = " Version 0.1";
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Declare pinmode's
pinMode(Button1, INPUT_PULLUP);
pinMode(Button2, INPUT_PULLUP);
pinMode(RedLed, OUTPUT);
pinMode(GreenLed, OUTPUT);
pinMode(LCDLight, OUTPUT);
analogWrite(LCDLight, 140); // brightness setting for LCD, 0-255 (0-5v)
// Welcome user on the LCD
lcd.print(" #ScaleSimTool#");
lcd.setCursor(0, 1);
lcd.print(vers);
lcd.clear();
lcd.print(" *ScaleSimTool*");
lcd.print(vers);
lcd.clear();
lcd.print(" /ScaleSimTool/");
lcd.print(vers);
lcd.clear();
lcd.print(vers);
lcd.clear();
lcd.print(vers);
lcd.clear();
lcd.print(vers);
lcd.clear();
lcd.print(".");
lcd.clear();
lcd.print("...");
lcd.clear();
lcd.print("......");
lcd.clear();
lcd.print("Starting Up!");
delay(1500);
lcd.clear();
lcd.print("Hello World :)");
unsigned long ScreenCurrentMls = millis();
unsigned long CurrentMls = millis();
unsigned long CurrentRandomMls = millis();
// Refresh Screen rate to prevent flickering
if (ScreenCurrentMls - ScreenMls >= ScreenRefreshInterval)
if (ScreenRefresh == 0)
ScreenRefresh = 1;
ScreenMls = ScreenCurrentMls;
Serial.println("Refresh 1");
ScreenRefresh = 0;
Serial.println("Refresh 0");
if (MenuPos == 6) { //checking requirements if it's ok to do random weighings
if (CurrentRandomMls - PreviousMls >= Interval) { //using an if statement to bypass the delay
// If Status & Random is on, but zero/max is off
Serial.println("Generating random values as test"); //using the serial tool as debug
RandomNr = random(MinRandom - MaxRandom); // Update the integer with a random number, Min&Max can be user defined
PreviousMls = CurrentRandomMls; //update Previous Milisecond integer to be used in the timer tool
Serial.println(RandomNr);
// Button 1 & 2 -> Endless loop setting BState1 high/low during the 'IntervalButton' period
// LCD&Serial print feedback enabled for debugging / development
if (Status == 1) {
if ((digitalRead(Button1) == LOW) && (BState1 == 0)) // Check if the button is pushed & if it's state is clear
BState1 = 1; //set button 'high' so this if is locked
PreviousMls = CurrentMls; //update timer int
Serial.println("Button 1 pressed"); //serial print for feedback
if (MenuPos < 6) {
MenuPos = MenuPos +1;
Serial.println(MenuPos);
if ((CurrentMls - PreviousMls >= IntervalButton) && (BState1 == 1)) // timer loop to prevent double pushing
BState1 = 0; //unlock again after 'IntervalButton' timer has passed
Serial.println("Button 1 state release");
if ((digitalRead(Button2) == LOW) && (BState2 == 0))
BState2 = 1;
Serial.println("Button 2 pressed");
if ((MenuPos <= 6) && (MenuPos > 0))
MenuPos = MenuPos -1;
else {
MenuPos = 0;
if ((CurrentMls - PreviousMls >= IntervalButton) && (BState2 == 1))
BState2 = 0;
Serial.println("Button 2 state release");
//########################################################### End of button loop
//####Menu buildup
if (Status == 1)
if (( MenuPos == 1) && (ScreenRefresh == 1))
lcd.clear();
lcd.print("Use Up and Down");
lcd.print("To navigate");
if (( MenuPos == 2) && (ScreenRefresh == 1))
lcd.clear();
lcd.print("1= Set Zero");
lcd.print("2= Set Max");
if (( MenuPos == 3) && (ScreenRefresh == 1))
lcd.clear();
lcd.print("3= Random Weight");
lcd.print("Next Scrn is 1");
if (( MenuPos == 4) && (ScreenRefresh == 1))
lcd.clear();
lcd.print("1 Setting Zero");
lcd.print(" Calibrate Scale");
if (( MenuPos == 5) && (ScreenRefresh == 1))
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("2 Setting Max");
if (( MenuPos == 6) && (ScreenRefresh == 1))
lcd.clear();
lcd.print("3 Random Weights");
lcd.print(" Testing Scale");
} //end void
