First Project need help please :/
Hey, I'm a beginner to Arduinos and working on a project that flashes my RGB led strip to the sound of music it also uses different colours for different frequency sounds, but I'm having a bit of trouble, I've wired and tested my circuit and it works well, although I cant get the script to work, if anyone could help me I'd really appreciate it.
It won't turn on or off the pins 3, 6 and 5.
I did not make the script, I found it on Youtube 300 RGB LED strip visualizer - YouTube
here's the script:
import processing.opengl.*;
import ddf.minim.signals.*;
import ddf.minim.*;
import ddf.minim.analysis.*;
import ddf.minim.effects.*;
import processing.serial.*;
import cc.arduino.*;
import controlP5.*;
Minim minim;
AudioInput in;
AudioPlayer song;
FFT fft;
PFont font;
int redPin = 3;
int greenPin = 6;
int bluePin = 5;
int sliders = 1;
int smoothedRed = 0;
int smoothedBlue = 0;
int smoothedGreen = 0;
boolean beat, mp3;
int smoother = 1;
float amp;
float[] leds;
int count, count2, anim, window, wave, k;
int RED, GREEN, BLUE;
int beattime;
int pbeattime;
Arduino arduino; // Setup an arduino object to communicate with Firmata firmware
BeatDetect beat2;
size(700, 510, OPENGL);
colorMode(RGB);
background(0);
arduino = new Arduino(this, Arduino.list()[1], 115200);
mp3 = false;
minim = new Minim(this);
beat2 = new BeatDetect();
if(mp3) {
song = minim.loadFile("song.mp3", 128);
beat2.detect(song.mix);
song.play();
fft = new FFT(song.bufferSize(), song.sampleRate()); }
else{
in = minim.getLineIn(Minim.STEREO, 1024);
beat2.detect(in.mix);
fft = new FFT(in.bufferSize(), in.sampleRate());
beat2.setSensitivity(300);
fft.logAverages(100, 4);
rectMode(CORNERS);
count = count2 = 0;
anim = 1;
beat = false;
window = 1;
k = 0;
beattime = pbeattime = 0;
void draw() {
if(mp3) beat2.detect(song.mix);
else beat2.detect(in.mix);
fill(0, 255);
rect (0, 0, width, height);
float[] leds = new float[fft.avgSize()];
if(beat) fill(0, 200, 200, 50);
rect(0, 0, width, height);
fill(150);
if(mp3) fft.forward(song.mix);
else fft.forward(in.mix);
int w = int(width/fft.avgSize());
for(int i = 0; i < fft.avgSize() && sliders == 1; i++)
float fftout = fft.getAvg(i);
amp = constrain(fftout*exp(fftout*.01)*exp(i/8)*.5, 0, 255);
if(window == 1){
fill(0, 200, 0, 50 + amp);
rect(i*w, height/2, i*w + w, height/2 - amp); //this draws the scaled spectrum
rect(i*w, height/2, i*w + w, height/2 + amp);
fill(0, 200, 100, 50 + amp);
rect(i*w, height/2, i*w + w, height/2 - fftout*2); //this draws raw spectrum on top
rect(i*w, height/2, i*w + w, height/2 + fftout*2);
leds[i] = amp;
if(sliders == 1){
if(leds[0] + leds[1] + leds[2] > 730) //this checks two bass bands and considers peaks to be a beat
beat = true;
else beat = false;
if(anim == 1) anim1(leds);
if(anim == 2) anim2(leds);
if(anim == 3) anim3(leds);
if(anim == 4) anim4(leds);
if(anim == 5) anim5(leds);
if(anim == 6) anim6(leds);
if(anim == 7) anim7(leds);
if(anim == 8) anim8(leds);
if(anim == 9) anim9(leds);
if(anim == 10) anim10(leds);
if(anim == 11) anim11(leds);
if(anim == 12) anim11(leds);
if(anim == 13) anim11(leds);
if(anim == 14) anim11(leds);
if(sliders == 2) drawSliders();
if(smoother == 1){
smoothVals();
RED = smoothedRed;
GREEN = smoothedGreen;
BLUE = smoothedBlue;
arduino.analogWrite(redPin, RED);
arduino.analogWrite(greenPin, GREEN);
arduino.analogWrite(bluePin, BLUE);
count++; //counts number of cycles since this anim started
println(+ count + " " + anim); //put any variable you want to monitor here
if(count > 200 && beat) { //this makes sure a certain amount of time passes
anim = int(random(1, 14)); //before changing anims
count = 0;
count2 = 0;
if(beat) {
count2 = 0;
pbeattime = beattime;
if(!beat){ //this times how long its been since a beat. after a certain point,
count2++; // Counts how long since a beat
if(count2 > 200){
anim = 1; //revert to anim1 if no beats for a while
count2 = 0;
void smoothVals(){
float filterVal = 0.5;
if (filterVal > 1){ // check to make sure param's are within range
filterVal = .99;
else if (filterVal <= 0){
filterVal = 0;
smoothedRed = int((RED * (1 - filterVal)) + (smoothedRed * filterVal));
smoothedGreen = int((GREEN * (1 - filterVal)) + (smoothedGreen * filterVal));
smoothedBlue = int((BLUE * (1 - filterVal)) + (smoothedBlue * filterVal));
void keyReleased(){
if(key == '1') //this forces a specific animation
anim += 1;
if(key == 's'){
if(sliders == 1) sliders = 2; //this toggles SA or LED sim
else sliders = 1;
if(key == 'f') //this forces a specific animation
smoother *= -1;
void drawSliders(){
RED = 255;
GREEN = 255;
BLUE = 122;
background(RED, GREEN, BLUE);
/*ANIMATIONS*/
void anim1(float leds[]) {
k++;
float angle = 0.001*k;
float sinmap = map(sin(angle), -1, 1, 0, fft.avgSize() - 1); //this creates a periodic fft band shifter
float cosmap = map(cos(angle*2), -1, 1, 0, fft.avgSize() - 1);
float sinmap2 = map(cos(2 + angle*3), -1, 1, 0, fft.avgSize() - 1);
RED = int(leds[int(sinmap)]);
GREEN = int(leds[int(cosmap)]);
BLUE = int(leds[int(sinmap2)]);
if(beat) getColor(); //getColor pulses a random color on every detected beat
void anim2(float leds[]) {
RED = 0;
GREEN = 0;
BLUE = int(leds[2]);
if(beat) {
int pRED = RED; //pRED is a placeholder variable for previous RED array location
RED = GREEN;
int pGREEN = GREEN;
GREEN = BLUE;
int pBLUE = BLUE;
BLUE = RED;
void anim3(float leds[]) {
RED = int(leds[2]);
GREEN = 0;
BLUE = 0;
if(beat) {
BLUE = RED;
GREEN = RED;
RED = GREEN;
void anim4(float leds[]) {
RED = int(leds[15]);
GREEN = 0;
BLUE = int(leds[6]);
if(beat) {
GREEN = int(leds[2]);
RED = int(leds[2]);
void anim5(float leds[]) {
k++;
float angle = 0.08*k;
if(beat) {
RED = 0;
void anim6(float leds[]) {
RED = 0;
GREEN = int(leds[15]);
BLUE = 0;
if(beat) {
getColor();
void anim7(float leds[]) {
GREEN = int(leds[15]*.25);
BLUE = 0;
if(beat){
BLUE = 255;
void anim8(float leds[]) {
RED = int(leds[15]*.8);
GREEN = 0;
BLUE = int(leds[15]*.25);
if(beat){
BLUE = 255;
RED = 255;
void anim9(float leds[]) {
GREEN = 0;
if(beat){
BLUE = 255;
RED = 255;
void anim10(float leds[]) {
RED = 0;
GREEN = 10;
BLUE = 10;
if(beat){
BLUE = 255;
GREEN = 255;
void anim11(float leds[]) {
RED = 0;
BLUE = int(leds[0]*2);
if(beat){
BLUE = 255;
RED = 255;
void anim12(float leds[]) {
RED = 10;
GREEN = 10;
BLUE = 10;
if(beat){
RED = 255;
BLUE = 255;
GREEN = 255;
void anim13(float leds[]) {
RED = 0;
GREEN = 0;
BLUE = 10;
if(beat){
RED = 0;
BLUE = 255;
GREEN = 0;
void anim14(float leds[]) {
RED = 10;
GREEN = 30;
BLUE = 10;
if(beat){
RED = 200;
BLUE = 255;
GREEN = 100;
void getColor() {
int temp = int(random(0, 7));
if(temp == 1) {
BLUE = 255;
GREEN = 0;
RED = 0;
if(temp == 2) {
BLUE = 0;
GREEN = 255;
RED = 0;
if(temp == 3) {
BLUE = 0;
GREEN = 0;
RED = 0;
if(temp == 4) {
BLUE = 255;
GREEN = 0;
RED = 255;
if(temp == 5) {
BLUE = 0;
GREEN = 255;
RED = 255;
if(temp == 6) {
BLUE = 150;
GREEN = 150;
RED = 255;
  1. So are we just suppose to guess what "doesn't work" means?
  2. When posting code please wrap it in code tags (the "#" symbol in the editor)
  3. Is this a Processing sketch, Arduino sketch, or combination?
Hello, I sorry about all that (I've corrected it).
This code is for Processing, it won't switch the pins on or off.
Thanks for the reply.
We really need properly indented code, its unreadable otherwise.
this is a first project ?! OMG, my first was blinking led...
xD I've already done that.
