Hello everyone,
I'm working on my first project and i need some help to understand a behavior of a part of my program.
Don't pay attention to all the comment, i took part of programs from example everywhere and didn't clean it yet.
My question is regarding the last part of my program.
i have an if statement and a else statement. The action in the if statement are not executed when the condition are met but the action in the else statement are executed when the if statement condition are not met. Here is the part of the program i'm talking about:
if (levelswitchstate == HIGH)
Serial.println("turn relay on");
Serial.println("turn relay off");
Here is the whole program :
#include <OneWire.h> // Library pour les sensor temperature OneWire (tous sur le meme input)
#include <DallasTemperature.h> //Librairy pour sensor temperature
#include <Event.h> //Librairy pour évenement callback(caller une fonction)
#include <Timer.h> //Librairy pour setter des timers
Timer timer1;
/*-----( Declare Constants and Pin Numbers )-----*/
#define ONE_WIRE_BUS_PIN 2
/*-----( Declare objects )-----*/
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS_PIN);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
/*-----( Declare Variables )-----*/
// Assign the addresses of your 1-Wire temp sensors.
// See the tutorial on how to obtain these addresses:
// http://www.hacktronics.com/Tutorials/arduino-1-wire-address-finder.html
DeviceAddress poolprobe = { 0x28, 0x8B, 0x3B, 0x26, 0x06, 0x00, 0x00, 0x50 };
DeviceAddress heaterprobe = { 0x28, 0xCD, 0x20, 0x2B, 0x06, 0x00, 0x00, 0x06 };
//DeviceAddress Probe03 = { 0x28, 0x4D, 0x8D, 0x40, 0x04, 0x00, 0x00, 0x78 };
//DeviceAddress Probe04 = { 0x28, 0x9A, 0x80, 0x40, 0x04, 0x00, 0x00, 0xD5 };
//DeviceAddress Probe05 = { 0x28, 0xE1, 0xC7, 0x40, 0x04, 0x00, 0x00, 0x0D };
const int levelswitch = 11;
int lastlevelswitchstate = LOW;
const int heatervalve = 10;
unsigned long lastDebounceTime = 0; // the last time the output pin was toggled
unsigned long debounceDelay = 500; // the debounce time; increase if the output flickers
void setup() /****** SETUP: RUNS ONCE ******/
// start serial port to show results
Serial.print("Initializing Temperature Control Library Version ");
Serial.println(DALLASTEMPLIBVERSION);
// Initialize the Temperature measurement library
sensors.begin();
// set the resolution to 10 bit (Can be 9 to 12 bits .. lower is faster)
sensors.setResolution(poolprobe, 10);
sensors.setResolution(heaterprobe, 10);
//sensors.setResolution(Probe03, 10);
// sensors.setResolution(Probe04, 10);
// sensors.setResolution(Probe05, 10);
timer1.every(1000, gettemp); // définir frequence de la fonction
timer1.every(5000, openvalve); // définir frequence de la fonction
timer1.every(1000, waterlevel);// check water level and change status of fillingvalve
}//--(end setup )---
void loop() /****** LOOP: RUNS CONSTANTLY ******/
timer1.update();
void gettemp()
Serial.print("Number of Devices found on bus = ");
Serial.println(sensors.getDeviceCount());
Serial.print("Getting temperatures... ");
// Command all devices on bus to read temperature
sensors.requestTemperatures();
Serial.print("Pool temperature is: ");
printTemperature(poolprobe);
Serial.print("Heater temperature is: ");
printTemperature(heaterprobe);
//Serial.print("Probe 03 temperature is: ");
//printTemperature(Probe03);
// Serial.println();
// Serial.print("Probe 04 temperature is: ");
// printTemperature(Probe04);
// Serial.print("Probe 05 temperature is: ");
// printTemperature(Probe05);
}//--(end main loop )---
/*-----( Declare User-written Functions )-----*/
void printTemperature(DeviceAddress deviceAddress)
float tempC = sensors.getTempC(deviceAddress);
if (tempC == -127.00)
Serial.print("Error getting temperature ");
Serial.print("C: ");
Serial.print(tempC);
Serial.print(" F: ");
Serial.print(DallasTemperature::toFahrenheit(tempC));
}// End printTemperature
//*********( THE END )***********
void openvalve()
pinMode (heatervalve, OUTPUT);
float pooltemp = sensors.getTempC(poolprobe);
float heatertemp = sensors.getTempC(heaterprobe);
if (pooltemp<heatertemp){
digitalWrite(heatervalve,HIGH);
Serial.println("on");
else{
digitalWrite(heatervalve,LOW);
Serial.println("off");
Serial.println(pooltemp);
Serial.println(heatertemp);
void waterlevel()
Serial.println("test");
pinMode (levelswitch, INPUT);
// read the state of the switch into a local variable:
int levelswitchstate = digitalRead(levelswitch);
Serial.println (levelswitchstate);
//if state changed
if (levelswitchstate != lastlevelswitchstate)
// reset the debouncing timer
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay)
// whatever the reading is at, it's been there for longer
// than the debounce delay, so take it as the actual current state:
// if the levelswitch state has changed:
lastlevelswitchstate = levelswitchstate;
Serial.println("turn relay on"); // This part isn't executed when condition if is met
Serial.println("turn relay off"); //this one is executed when the if condition isn't met
//float tempC = sensors.getTempC(deviceAddress);
I guess it's a pretty simple error but i can't figured it out.
Best regards
