First time building a library, compile issues
I am working with a graphical LCD which has a large number of serial commands for different functions.
In an attempt to clean up my workflow and to simplify my code i have attempted to build a library, unfortunatly without too much success. I have followed the stock tutorial and compared against other libraries i have downloaded yet i cannot get mine to function.
As a secondary question, does anyone have an alternative to the arduino IDE that will allow me to edit these C based files with highlighting, as well as compiling and downloading arduino programs.
Program file:
#include <lcd.h>
lcd lcdLib()
void setup(){
void loop(){
compiler report:
In file included from sketch_apr09a.cpp:1:
C:\Users\Apothus\Documents\Arduino\libraries\LCD/lcd.h:15: error: expected unqualified-id before ')' token
sketch_apr09a:0: error: new types may not be defined in a return type
sketch_apr09a.cpp:4: note: (perhaps a semicolon is missing after the definition of '')
sketch_apr09a:0: error: two or more data types in declaration of 'setup'
sketch_apr09a:2: error: expected constructor, destructor, or type conversion before ';' token
Header file lcd.h:
//Library header for simple serial code.
#ifndef lcd
#define lcd
//attached libraries
#include "Arduino.h"
class lcd
public:
  lcd();
  void clr();
  int backlight(int level);
  int circle(int x, int y, int radius, int set);
  void crlfTog();
  void reset();
  void fontTgl();
  int fontMode(int mode);
  int line(int xOne, int yOne, int xTwo, int yTwo, int setR);
  int box(int xOne, int yOne, int xTwo, int yTwo, int setR);
  int fBox(int xOne, int yOne, int xTwo, int yTwo, int setR);
  int pixel(int x, int y, int setR);
  void reverse();
  void setX(int x);
  void setY(int y);
  private:
  int coOrd(int xOne, int yOne, int xTwo, int yTwo, int setR);
  void cmd();
#endif
Source file lcd.cpp
// Libarary source for simple serial code
#include "lcd.h"
lcd::lcd()
  //empty construct
void lcd::clr()
  lcd.cmd();					//calls the subroutine cmd, unsure if this will work though
  Serial.write((byte)0x00);
int lcd::backlight(int level)
 int ok = 0;
  if( level >=0 && level <=64){    //hexadecmial check
  lcd.cmd();
  Serial.write((byte)0x02);
  Serial.write((byte)level);
  ok = 1;
  return ok;
int lcd::circle(int x, int y, int radius, int set)		//Draw a circle on screen at point x,y with radius
int ok = 0;
  if( x>=0 && x<= 0x7f){                    // x error check, 0 if fail
    if( y >= 0 && y <= 0x3f){               // y error check, 1 if fail
      if( radius > 0 && radius <= 0x7F){    // radius error check, 2 if fail
        if( set < 2){                       // set error check, 3 if fail, 4 if all OK
          lcd.cmd();
          ok = 4;
          Serial.write((byte)0x03);
          Serial.write((byte)x);
          Serial.write((byte)y);
          Serial.write((byte)radius);
          Serial.write((byte)set);
        else{
          ok = 3;
      else{
        ok = 2;
    else{
      ok = 1;
 return ok;
void lcd::crlfTog()	// toggle automatic carridge return and line feed
lcd.cmd();
  Serial.write((byte)0x04);
void lcd::reset()	//clear display and reset x&y offsets
lcd.cmd();
  Serial.write((byte)0x06);
void lcd::fontTgl()	//toggle between primary and alternate font
lcd.cmd();
  Serial.write((byte)0x08);
int lcd::fontMode(int mode)	//font draw mode setting
  int ok = 0;
  if( mode >= 0 && mode <= 7){
    ok = 1;
    cmd();
    Serial.write((byte)0x0A);
    Serial.write((byte)mode);
 return ok;
int lcd::line(int xOne, int yOne, int xTwo, int yTwo, int setR)	//draws a line using cartesian co-ords
  int ok = 0;
  if(coOrd(xOne, yOne, xTwo, yTwo, setR) == 1){
    ok = 1;
    cmd();
    Serial.write((byte)0x0C);
    Serial.write((byte)xOne);
    Serial.write((byte)yOne);
    Serial.write((byte)xTwo);
    Serial.write((byte)yTwo);
    Serial.write((byte)setR);
  return ok;
int lcd::box(int xOne, int yOne, int xTwo, int yTwo, int setR)		//draws a box, much like the others
  int ok = 0;
  if(lcd.coOrd(xOne, yOne, xTwo, yTwo, setR) == 1){				//check if valid inputs with coOrd routine
    ok = 1;
    cmd();
    Serial.write((byte)0x0F);
  return ok;
int lcd::fBox(int xOne, int yOne, int xTwo, int yTwo, int setR)		//draws a filled in box
  int ok = 0;
    ok = 1;
    lcd.cmd();
    Serial.write((byte)0x12);
  return ok;
int lcd::pixel(int x, int y, int setR)		//draw or clear specific pixel
  int ok = 0;
  if( x >= 0 && x <= 0x7f){
    if( y>= 0 && y <= 0x3f){
      if( setR ==0 | setR == 1){
        ok = 1;
        lcd.cmd();
        Serial.write((byte)0x10);
  return ok;
void lcd::reverse()		//inverts the display
  lcd.cmd();
  Serial.write((byte)0x14);
void lcd::setX(int x)		//set x offset
  if( x>= 0 && x<=0x7f){
    lcd.cmd();
    Serial.write((byte)0x18);
void lcd::setY(int y)		//set y offset
  if( y>= 0 && y<= 0x7f){
    lcd.cmd();
    Serial.write((byte)0x19);
void lcd::cmd()		//writes the command prefix to the LCD, preceeds all command functions
    Serial.write((byte)0x7C);
int lcd::coOrd(int xOne, int yOne, int xTwo, int yTwo, int steR)	// tests if value passed is in range
    int ok = 0;
  if( xOne >= 0 && xOne <= 0x7F){
    if( xTwo >= 0 && xTwo <= 0x7F){
      if( yOne >= 0 && yOne <= 0x3F){
        if( yTwo >= 0 && yTwo <= 0x3F){
          if( setR == 0 | setR == 1 ){
            ok = 1;
  return ok;
Any advice on my code would be appreciated. It has been a long time since i have written librarys or header files. I am also unclear on the case requirements for the arduino, i know that C can be a little sensitive to case at times.
lcd lcdLib()
Lose the () and add a ;.
you have missed a semicolon at the end of the closing } brace of the class def in your lcd.h file. Also missed in your sketch when you declare the object.
secondly, as a general good practice, when you are writing libraries, try to choose more unique names for your classes and files to prevent potential conflicts with other more generic libraries... eg. lcd_graphics controller model
You may want to brush up on C++ classes from any number of tutorials on the web... Arduino libraries simply consist of c++ classes
Thanks for the help. Now i know they are the same I am sure i can find a lot more matterial and examples.
Much appreciated.
As a note for others, the library requires the addition of "_h" at the end of the #ifndef description
