First timer using MKRWAN1300
I’ve recently bought a COZIR-AH-1 CO2 sensor for my project and to connect it with a MKRWAN1300 to use LoRa communication. I can’t seem to get the sensor working with the MKRWAN 1300 with the example codes that are online.
Do you think it can work with the MKRWAN board?
Probably. You might get the Arduino cookbook and read it. Also on line there are many videos etc showing the Arduino and how to do what you want. This additional information will go a long way in getting your problem solved. Once you get past this you can start on the hardware design and write your software.
