Hello,
I want to switch a running project that communicates via BTooth to air communication, to centralize device performance and accept setup parameters on the air instead of proximity setup.
We are aware of 2G limitations of 800L, but in the short term it will be available in South America.
Our devices target Arduino Uno for small models, and ESP32 for bigger ones.
The first question is to select if going via AT commands, there are many running examples, or if use a library (TinyGSM) or the like.
Our info exchange is very little volume
Writing 6 times a day a char stream to activate a php script that inserts a record in a mySql,
Reading once a day a setup configuration char stream of 80 bytes.
Writing, in case of going via TinyGsm, can be represented as:
Thanks for your guidance !
Kind regards,
Horacio
