Fish Feeder
Good day, I am new to Arduino, but have made some nice projects work. I have a n issue with a Auto fish feeder. I have used a servo that I modified to run 360. I am having a issue when the Nano board starts. It runs the time I have set between feeds, and then it stops. If I set it to feed every 10 sec, it starts up and run for 10sec and then the LED flashes and it stops. From there it works perfect. But if I lose power and it comes back, its going to feed for 10sec and that will kill the fish.
Here is my sketch attached I am using now, please can someone look at it and tell me where I am going wrong. I just want it not to run when it starts up, or just for the to that it feeds, not continues like now for 10sec, or 12 hours !!!
//--Setting Vars
   //Fish Feeder Vars.
int pinOutMotor = 3;
int pinOutLed = 5;
int pinInButton = 2;
int MotorRunDuration = 1000;
float AutoWaitDurationHours = 0.;
//--Program Vars
unsigned long currentMsSinceStart = 0;
unsigned long msValueAtLastRun = 0;
float HoursSinceLastRun = 0;
int buttonValue = 0;
  Serial.begin(9600);             //Turns on serial monitor.
  pinMode(pinOutMotor, OUTPUT);   //Is controlled by a 3906 npn transistor to switch the motor off and on.  When program started I need to add a line to turn off motor when program was started.
  pinMode(pinInButton, INPUT);    //Manual feed.
  pinMode(pinOutLed, OUTPUT);     //Shows motor is on when lite.
  //HoursSinceLastRun = AutoWaitDurationHours - 0.05; //this will make it run 3 minutes after turned on.
//Fish Feeder
  //get miliseconds since program start and calc.
  currentMsSinceStart = millis();
  HoursSinceLastRun = (currentMsSinceStart - msValueAtLastRun) / 43200000; //10000 millis= 10 seconds.  To change the time to vary feeding times set for 12hrs type in 43200000 or 6hrs tyoe in 21600000.
  //check for button press
  buttonValue = digitalRead(pinInButton);
  if(buttonValue == HIGH){  //had to change state because of button from LOW to HIGH.
    //run motor for button press.
    RunMotor();
    Serial.println("Feed Fish Manually");  //serial print funtion completed by button
  } else if(HoursSinceLastRun > AutoWaitDurationHours){
    RunMotor();
    msValueAtLastRun = currentMsSinceStart;
    Serial.println("Feed Fish Auto");      //serial print funtion completed by auto wait duration hours
  //slow the loop down so it isn't running at full CPU Utilization for nothing.
  delay(50); //delay 1/20th of a second.
void RunMotor(){
    analogWrite(pinOutMotor, 0);   // turn on motor
    analogWrite(pinOutLed, 80);        // turn on green led to show motor is on.
    delay(MotorRunDuration);   // wait for motor run duration to expire
    analogWrite(pinOutMotor, 255);    // turn off motor
    analogWrite(pinOutLed, 0);        // turn off green led to show motor is off.
auto_fish_feeder_with_manual_feed.txt (2.12 KB)
Do you need to use a continuous rotation "servo" ?
The program has no way of knowing it's position
 float AutoWaitDurationHours = [color=red]0[/color].;
do you really mean 0? (and do you mean float?)
UKHeliBob:
depending the way the feeder works, it might be driving a worm screw that drives the flakes into the water, so basically it's just a motor that has to spin, no need for a servo
(source)
J-M-L:
Yes this is 100% the same, I did this project from Thingiverse
Everything works, its just the start, its runs for the time that should be delayed between feeds first. In my sketch its 10sec, if I make it 20sec, the servo runs for 20sec before it goes to the first feed. I need to have feed as the first action and then delay
J-M-L:
I am really green an do not know what it should be.......
Loeikie:
well your code in the loop reads like this
    RunMotor();
  } else if([color=red]HoursSinceLastRun > AutoWaitDurationHours[/color]){
    RunMotor();
after a few milliseconds (the loop spins quickly) what do you think the result of the test HoursSinceLastRun > AutoWaitDurationHours will be given HoursSinceLastRun is a floating point value and AutoWaitDurationHours is worth 0
J-M-L:
    RunMotor();
    RunMotor();
Also 0..... ?
forget what I said, the math (currentMsSinceStart - msValueAtLastRun) / 43200000 is done in unsigned long as those values are not float - only where you store the result. so indeed you get an integral value regardless of the fact that you store the result in a float, so the if does not trigger (I had assumed that very quickly HoursSinceLastRun would become 0,0000001 and thus the if would trigger)
Issue might be elsewhere: do you have a pull down on your button?
Try this example of a state machine. I think that if nothing else its operation is easier to follow that your program.
const byte ledPin = 13;
typedef enum
  WAITING,
  FEEDING
} state;
byte currentState = WAITING;
unsigned long periodStart = millis();
unsigned long currentTime;
unsigned long period = 5000;
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, LOW);
  currentTime = millis();
  switch (currentState)
    case WAITING:
      if (currentTime - periodStart >= period)
        digitalWrite(ledPin, HIGH);
        period = 1000;
        periodStart = currentTime;
        currentState = FEEDING;
    case FEEDING:
        period = 5000;
As written it turns an LED on and off but is easily modified to drive a servo and to change the timing periods used.
To add manual feeding read the button in loop() and when the button becomes pressed set the state to FEEDING
J-M-L:
J-M-L I feel very dumb at the moment, I have no idea what you mean by " a pull down on your button" ?
If an input pin is not held at either HIGH or LOW at all times it is susceptible to picking up stray voltages causing the Arduino to act as if the button has been pressed. A pulldown resistor connecting the pin to GND would keep the pin in a known LOW state until the button is pressed to connect it to 5V to take it HIGH
UKHeliBob:
Ahh !!!! I have removed the Button ! and the res, so you are saying that it may not read this correctly then ?
I will put the button back and see what happens
The simplest way to deal with the need to keep digital input pins in a known state is to use
pinMode(pin, INPUT_PULLUP);
which turns on the built in pullup resistor. The button needs to be wired to take the pin LOW when pressed and any logic in the program needs to match the "LOW equals pressed, HIGH equals not pressed" model.
