Fix for Blurry interface?
Installed latest version to find the entire interface is blurry. Looking through the options I found a new interface scaling option, set to automatic. Thought it was weird as that should use my system DPI settings then which is set to 100% for a 1920x1080 screen. Tried unchecking the automatic option and setting to 100%. Nope still blurry. Tried going into the preferences file and found anti aliasing is set to true by default, disabled that. Nope still blurry, but better.
Downloaded and installed 1.6.7, the last version before the interface scaling, and everything is back to normal.
This bug was reported at: https://github.com/arduino/Arduino/issues/5750 It's isolated to Arduino IDE 1.8.0 and was not caused by the addition of the interface scaling feature.
You don't need to go all the way back to 1.6.7, you can avoid it by using Arduino IDE 1.6.13 or if you're feeling adventurous you could test the hourly build from: http://www.arduino.cc/en/Main/Software#hourly which should have the bug fixed.
latest hourly does appear to fix the problem.
