FQBN: deauther:esp8266:nodemcuv2:wipe=all
Using board 'nodemcuv2' from platform in folder: C:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4
Using core 'esp8266' from platform in folder: C:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4
Detecting libraries used...
C:\Users\tranl\AppData\Local\Arduino15\packages\deauther\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4/tools/sdk/include -IC:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4/tools/sdk/lwip2/include -IC:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\tranl\AppData\Local\Temp\arduino\sketches\4E163ADCD5C814DB2DA7E9B344E70BF0/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=160000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DFLASHMODE_DIO -DESP8266 -DNODEMCU -IC:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4\cores\esp8266 -IC:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4\variants\nodemcu C:\Users\tranl\AppData\Local\Temp\arduino\sketches\4E163ADCD5C814DB2DA7E9B344E70BF0\sketch\Blink.ino.cpp -o nul
Generating function prototypes...
C:\Users\tranl\AppData\Local\Arduino15\packages\deauther\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4/tools/sdk/include -IC:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4/tools/sdk/lwip2/include -IC:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\tranl\AppData\Local\Temp\arduino\sketches\4E163ADCD5C814DB2DA7E9B344E70BF0/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=160000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DFLASHMODE_DIO -DESP8266 -DNODEMCU -IC:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4\cores\esp8266 -IC:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4\variants\nodemcu C:\Users\tranl\AppData\Local\Temp\arduino\sketches\4E163ADCD5C814DB2DA7E9B344E70BF0\sketch\Blink.ino.cpp -o C:\Users\tranl\AppData\Local\Temp\2894016319\sketch_merged.cpp
C:\Users\tranl\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\tranl\AppData\Local\Temp\2894016319\sketch_merged.cpp
Compiling sketch...
"C:\Users\tranl\AppData\Local\Arduino15\packages\deauther\tools\python3\3.7.2-post1/python3" "C:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4/tools/signing.py" --mode header --publickey "C:\Users\tranl\AppData\Local\Temp\.arduinoIDE-unsaved2024815-7560-tjl3pr.ntn1n\Blink/public.key" --out "C:\Users\tranl\AppData\Local\Temp\arduino\sketches\4E163ADCD5C814DB2DA7E9B344E70BF0/core/Updater_Signing.h"
"C:\Users\tranl\AppData\Local\Arduino15\packages\deauther\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4/tools/sdk/include" "-IC:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4/tools/sdk/lwip2/include" "-IC:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\tranl\AppData\Local\Temp\arduino\sketches\4E163ADCD5C814DB2DA7E9B344E70BF0/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++11 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DNONOSDK22x_190703=1 -DF_CPU=160000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_NODEMCU"" -DFLASHMODE_DIO -DESP8266 -DNODEMCU "-IC:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4\cores\esp8266" "-IC:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4\variants\nodemcu" "C:\Users\tranl\AppData\Local\Temp\arduino\sketches\4E163ADCD5C814DB2DA7E9B344E70BF0\sketch\Blink.ino.cpp" -o "C:\Users\tranl\AppData\Local\Temp\arduino\sketches\4E163ADCD5C814DB2DA7E9B344E70BF0\sketch\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\tranl\AppData\Local\Temp\arduino\cores\760f7aec07b0c57e0390144dcf46b730\core.a
Linking everything together...
"C:\Users\tranl\AppData\Local\Arduino15\packages\deauther\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506/bin/xtensa-lx106-elf-gcc" -CC -E -P -DVTABLES_IN_FLASH "C:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4/tools/sdk/ld/eagle.app.v6.common.ld.h" -o "C:\Users\tranl\AppData\Local\Temp\arduino\sketches\4E163ADCD5C814DB2DA7E9B344E70BF0/local.eagle.app.v6.common.ld"
"C:\Users\tranl\AppData\Local\Arduino15\packages\deauther\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506/bin/xtensa-lx106-elf-gcc" -fno-exceptions -Wl,-Map "-Wl,C:\Users\tranl\AppData\Local\Temp\arduino\sketches\4E163ADCD5C814DB2DA7E9B344E70BF0/Blink.ino.map" -g -w -Os -nostdlib -Wl,--no-check-sections -u app_entry -u _printf_float -u _scanf_float -Wl,-static "-LC:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4/tools/sdk/lib" "-LC:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4/tools/sdk/lib/NONOSDK22x_190703" "-LC:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4/tools/sdk/ld" "-LC:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4/tools/sdk/libc/xtensa-lx106-elf/lib" -Teagle.flash.4m1m.ld -Wl,--gc-sections -Wl,-wrap,system_restart_local -Wl,-wrap,spi_flash_read -o "C:\Users\tranl\AppData\Local\Temp\arduino\sketches\4E163ADCD5C814DB2DA7E9B344E70BF0/Blink.ino.elf" -Wl,--start-group "C:\Users\tranl\AppData\Local\Temp\arduino\sketches\4E163ADCD5C814DB2DA7E9B344E70BF0\sketch\Blink.ino.cpp.o" "C:\Users\tranl\AppData\Local\Temp\arduino\cores\760f7aec07b0c57e0390144dcf46b730\core.a" -lhal -lphy -lpp -lnet80211 -llwip2-536-feat -lwpa -lcrypto -lmain -lwps -lbearssl -laxtls -lespnow -lsmartconfig -lairkiss -lwpa2 -lstdc++ -lm -lc -lgcc -Wl,--end-group "-LC:\Users\tranl\AppData\Local\Temp\arduino\sketches\4E163ADCD5C814DB2DA7E9B344E70BF0"
"C:\Users\tranl\AppData\Local\Arduino15\packages\deauther\tools\python3\3.7.2-post1/python3" "C:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4/tools/elf2bin.py" --eboot "C:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4/bootloaders/eboot/eboot.elf" --app "C:\Users\tranl\AppData\Local\Temp\arduino\sketches\4E163ADCD5C814DB2DA7E9B344E70BF0/Blink.ino.elf" --flash_mode dio --flash_freq 40 --flash_size 4M --path "C:\Users\tranl\AppData\Local\Arduino15\packages\deauther\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506/bin" --out "C:\Users\tranl\AppData\Local\Temp\arduino\sketches\4E163ADCD5C814DB2DA7E9B344E70BF0/Blink.ino.bin"
Creating BIN file "C:\Users\tranl\AppData\Local\Temp\arduino\sketches\4E163ADCD5C814DB2DA7E9B344E70BF0/Blink.ino.bin" using "C:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4/bootloaders/eboot/eboot.elf" and "C:\Users\tranl\AppData\Local\Temp\arduino\sketches\4E163ADCD5C814DB2DA7E9B344E70BF0/Blink.ino.elf"
"C:\Users\tranl\AppData\Local\Arduino15\packages\deauther\tools\python3\3.7.2-post1/python3" "C:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4/tools/signing.py" --mode sign --privatekey "C:\Users\tranl\AppData\Local\Temp\.arduinoIDE-unsaved2024815-7560-tjl3pr.ntn1n\Blink/private.key" --bin "C:\Users\tranl\AppData\Local\Temp\arduino\sketches\4E163ADCD5C814DB2DA7E9B344E70BF0/Blink.ino.bin" --out "C:\Users\tranl\AppData\Local\Temp\arduino\sketches\4E163ADCD5C814DB2DA7E9B344E70BF0/Blink.ino.bin.signed" --legacy "C:\Users\tranl\AppData\Local\Temp\arduino\sketches\4E163ADCD5C814DB2DA7E9B344E70BF0/Blink.ino.bin.legacy_sig"
"C:\Users\tranl\AppData\Local\Arduino15\packages\deauther\tools\python3\3.7.2-post1/python3" "C:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4/tools/sizes.py" --elf "C:\Users\tranl\AppData\Local\Temp\arduino\sketches\4E163ADCD5C814DB2DA7E9B344E70BF0/Blink.ino.elf" --path "C:\Users\tranl\AppData\Local\Arduino15\packages\deauther\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506/bin"
Executable segment sizes:
IROM : 228624 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 26756 / 32768 - code in IRAM (ICACHE_RAM_ATTR, ISRs...)
DATA : 1248 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 688 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 24880 ) - zeroed variables (global, static) in RAM/HEAP
"C:\Users\tranl\AppData\Local\Arduino15\packages\deauther\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506/bin/xtensa-lx106-elf-size" -A "C:\Users\tranl\AppData\Local\Temp\arduino\sketches\4E163ADCD5C814DB2DA7E9B344E70BF0/Blink.ino.elf"
Sketch uses 257316 bytes (24%) of program storage space. Maximum is 1044464 bytes.
Global variables use 26816 bytes (32%) of dynamic memory, leaving 55104 bytes for local variables. Maximum is 81920 bytes.
"C:\Users\tranl\AppData\Local\Arduino15\packages\deauther\tools\python3\3.7.2-post1/python3" "C:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4/tools/upload.py" --chip esp8266 --port "COM4" --baud "115200" "" erase_flash --before default_reset --after hard_reset write_flash 0x0 "C:\Users\tranl\AppData\Local\Temp\arduino\sketches\4E163ADCD5C814DB2DA7E9B344E70BF0/Blink.ino.bin"
esptool.py v2.8
Serial port COM4
Traceback (most recent call last):
File "C:\Users\tranl\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.4/tools/upload.py", line 65, in
esptool.main(cmdline)
File "C:/Users/tranl/AppData/Local/Arduino15/packages/deauther/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 2889, in main
esp = chip_class(each_port, initial_baud, args.trace)
File "C:/Users/tranl/AppData/Local/Arduino15/packages/deauther/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 237, in init
self.port = serial.serial_for_url(port)
File "C:/Users/tranl/AppData/Local/Arduino15/packages/deauther/hardware/esp8266/2.7.4/tools/pyserial\serial_init.py", line 88, in serial_for_url
instance.open()
File "C:/Users/tranl/AppData/Local/Arduino15/packages/deauther/hardware/esp8266/2.7.4/tools/pyserial\serial\serialwin32.py", line 62, in open
raise SerialException("could not open port {!r}: {!r}".format(self.portstr, ctypes.WinError()))
serial.serialutil.SerialException: could not open port 'COM4': PermissionError(13, 'Access is denied.', None, 5)
Failed uploading: uploading error: exit status 1
