for all users in this forum, can you guys help me to fix what is wrong from this sketch so it does not work ...
i want to make ir remote sketch like orvibo or universal xiaomi remote but it does not work and i do not know the location of my sketch error ...
#define IRpin_PIN PIND
#define IRpin 2
char val;
// The maximum pulse we'll listen for - 65 milliseconds is a long time
#define MAXPULSE 65000
// Timing resolution
#define RESOLUTION 20
int IRledPin = 3; // IR emitter LED connected to digital pin 3
int buttonState1 = 0;
int buttonState2 = 0;
// Store up to 100 pulse pairs
uint16_t pulses[300][2]; // Pair is high and low pulse
uint8_t currentpulse = 0; // Index for pulses we're storing
uint8_t sendpulse = 0; // Index for send pulses
void setup(void) {
// Set uart baudrate
void loop(void) {
if( Serial.available() >0 ) {
val = Serial.read();
Serial.println(val);}
if (val == 'A') {
Serial.println("Sending IR signal");
SendIRCode();
//delay(15); // wait 15 milliseconds before sending it again
//SendIRCode(); // repeat IR code if it is neccesary
Serial.println(sendpulse);
delay(5000); // wait 5 seconds to resend the code
if ((val == 'a') || (currentpulse != 0)){
if (val == 'a'){
Serial.println("Ready to decode IR!");
uint16_t highpulse, lowpulse; // Temporary storage timing
highpulse = lowpulse = 0; // Start out with no pulse length
while (IRpin_PIN & (1 << IRpin)) {
// count off another few microseconds
highpulse++;
delayMicroseconds(RESOLUTION);
// If the pulse is too long, we 'timed out' - either nothing
// was received or the code is finished, so print what
// we've grabbed so far, and then reset
if ((highpulse >= MAXPULSE) && (currentpulse != 0)) {
printpulses();
sendpulse=currentpulse;
currentpulse=0;
return;
// we didn't time out so lets stash the reading
pulses[currentpulse][0] = highpulse;
// same as above
while (! (IRpin_PIN & _BV(IRpin))) {
// pin is still LOW
lowpulse++;
if ((lowpulse >= MAXPULSE) && (currentpulse != 0)) {
printpulses();
currentpulse=0;
return;
pulses[currentpulse][1] = lowpulse;
// we read one high-low pulse successfully, continue!
currentpulse++;
void printpulses(void) {
// Start declaration
Serial.print("unsigned int ");
Serial.print("rawData[");
Serial.print((currentpulse *2)-1, DEC);
Serial.print("] = {");
for (uint8_t i = 0; i < currentpulse; i++) {
if (i != 0){
Serial.print("");
Serial.print(pulses_[0] * RESOLUTION);_
- Serial.print(", ");*
- Serial.print("");*
Serial.print(pulses_[1] * RESOLUTION);_
* Serial.print(", ");*
* // End declaration*
* Serial.print("};"); //*
* // Comment*
* delay(1000);*
// This procedure sends a 38KHz pulse to the IRledPin for a certain # of microseconds.
void pulseIR(long microsecs) {
* cli(); // Turn off any background interrupts*
* while (microsecs > 0) {*
* // 38 kHz is about 13 microseconds high and 13 microseconds low*
* digitalWrite(IRledPin, HIGH); // 3 microseconds*
_ delayMicroseconds(10); /* hang out for 10 microseconds,
you can also change this to 9 if its not working /_
_ digitalWrite(IRledPin, LOW); // 3 microseconds*_
you can also change this to 9 if its not working */_
* // So 26 microseconds altogether*
* microsecs -= 26;*
* sei(); // Turn them back on*
void SendIRCode() {
* Serial.print(" irsend.sendRaw ({");*
* for (uint8_t i = 0; i < sendpulse; i++) {*
* if (i != 0){*
delayMicroseconds(pulses_[0] * RESOLUTION);
Serial.print(pulses[0] * RESOLUTION);
}*_
pulseIR(pulses_[1] * RESOLUTION);
Serial.print(pulses[1] * RESOLUTION);
// End declaration*
* Serial.print("},");
Serial.print((sendpulse 2)-1, DEC);
Serial.print(",38);//");_
