Fixed-point Exponential Moving Average filter with given cutoff frequency
Hello,
I want to implement in fixed point arithmetic an exponential moving average filter, with a specific cutoff frequency for a given sampling rate.
The formula for the filter is y[n] = alpha * x[n] + (1 - alpha) * y[n-1]
Looking at filters - Exponential moving average cut-off frequency - Signal Processing Stack Exchange one can derive the value for alpha for a given sampling rate and a wanted cutoff. For instance, for a sampling rate of 1000 Hz and a cutoff of 50 Hz, the value of alpha is 0.267730531659313:
Fs = 1000
f3db = 50 %This is the cutoff frequency that I want
format long;
omega3db = f3db * pi/(Fs/2)
alpha = cos(omega3db) - 1 + sqrt(cos(omega3db).^2 - 4*cos(omega3db) + 3) = 0.267730531659313
Now I tried to implement the exponential moving average filter in fixed point arithmetic as described here: Ten Little Algorithms, Part 2: The Single-Pole Low-Pass Filter - Jason Sachs but I am getting an offset that I can't explain,
Here my code:
#define PERIOD_MICROSECS 1000
static unsigned long lastRead = 0;
int analog_pin = 0;   // sensor connected to analog pin 0
int analog_input0 = 0;  // variable to store the read value;
int analog_input0_filtered_fixed_point = 0;
 * Formula to compute the alpha parameter of the EMA given a desired cutoff frequency.
 * Taken from: https://dsp.stackexchange.com/questions/40462/exponential-moving-average-cut-off-frequency
 * Fs = 1000
 * f3db = 50 %This is the cutoff frequency that I want
 * format long;
 * omega3db = f3db * pi/(Fs/2)
 * alpha = cos(omega3db) - 1 + sqrt(cos(omega3db).^2 - 4*cos(omega3db) + 3)  =  0.267730531659313
//I calculate in advance the coefficients for the filter
int Q = 12; // I can choose Q freely
//I want a cutoff of 50Hz at a sampling frequency of 1000 Hz. So I calculate the corresponding alpha with formula above
//For cutoff 50 Hz, alpha = 0.267730531659313; then alpha_scaled = round(2^Q*alpha) = round(2^12* 0.267730531659313) = round(4096* 0.267730531659313) = 1097
int alpha_scaled = 1097;
// N ~= -log_2(alpha) = -log_2(0.267730531659313) = 1.901146423365515 ~ 2
int N = 2;
int low_pass_EMA_fixed_point(int x, int y, int alpha_scaled, int Q, int N){
  y += (alpha_scaled * (x-y)) >> (Q-N);
  return y >> N;
  analog_input0_filtered_fixed_point = analogRead(analog_pin); //set EMA y for t=1
  if (micros() - lastRead >= PERIOD_MICROSECS) {
        lastRead += PERIOD_MICROSECS;
        analog_input0 = analogRead(analog_pin);
        analog_input0_filtered_fixed_point = low_pass_EMA_fixed_point(analog_input0, analog_input0_filtered_fixed_point, alpha_scaled, Q, N);
        //Check the original and filtered signals with the serial plotter
        Serial.print(analog_input0);
        Serial.print(" ");
        Serial.println(analog_input0_filtered_fixed_point);
See attached a plot with the serial plotter.
Any idea about how to solve the offset problem? What am I doing wrong? Any suggestion about how to solve the general problem of a fixed point exponential moving average filter with a specific cutoff frequency?
If you're using Arduino Uno, the size of integer is 16 bit, with a range -32768 to 32767.
Your alpha_scaled constant is 1097, 11 bit. If (x-y) size is >= 5 bit, the signed integer multiplication overflows.
For example, if (x-y) = 32 then alpha_scaled * (x-y) = 1097 * 32 = 35104 > 32767 --> overflow.
So, if you're on Arduino Uno, try using long integers, 32 bit.
Many thanks! Of course this was an error. However, even substituting all int with int32_t the problem persists. Here the updated code:
int32_t analog_pin = 0;   // sensor connected to analog pin 0
int32_t analog_input0 = 0;  // variable to store the read value;
int32_t analog_input0_filtered_fixed_point = 0;
 * Fs = 1000
 * format long;
int32_t Q = 12; // I can choose Q freely
int32_t alpha_scaled = 1097;
int32_t N = 2;
int32_t low_pass_EMA_fixed_point(int32_t x, int32_t y, int32_t alpha_scaled, int32_t Q, int32_t N){
  return y >> N;
        Serial.print(" ");
Any idea about how to solve the issue?
Well
in my opinion, that instruction can't work.
In input to function low_pass_EMA_fixed_point(), y is an integer.
But
is a fixed point number with Q binary digits after decimal point, and
is a fixed point number with N binary digits after decimal point.
So
is a misaligned sum of an integer with a fixed point number.
The right way to do this, is to align y before sum
 int32_t scaled_dy = (alpha_scaled * (x-y)) >> (Q-N); // scaled_dy is a fixed point number with N binary digit after decimal point
 scaled_y = y << N; // scaled_y is now a fixed point number with N binary digit (all 0) after decimal point
 scaled_y += scaled_dy; // aligned sum of fixed point numbers
 return(scaled_y >> N); // return an integer, converting the fixed point with N binary digit after decimal point
But this way I don't understand the N thing meaning: the function low_pass_EMA_fixed_point() always skips the N extra binary digit without incrementing filter precision, I think something is missed.
Maybe you must preserve scaled_y value, so the intended function is:
int32_t scaled_y = 0; // static fixed point variable for running sum with N binary digit after decimal point
 scaled_y += (alpha_scaled * (x-y)) >> (Q-N); // scaled_y is a fixed point number with N binary digit after decimal point
