[Fixed] Programer won't respond.
The Programmer won't respond.
Error Message:
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 1262 bytes (3%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x75
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
Please Help!
Are you connected to the right port and the right board. if not go to tools >port and tools>board. hope this helps
Yes I am always connected to the UNO
I even tried reinstalling the IDE and it still didn't work.
I had version 1.8.5 before, but now I have version 1.8.8.
I have the Snap Circuits Snapino module with the UNO built in.
HELP
Here is the new error message:
Arduino: 1.8.8 (Windows Store 1.8.19.0) (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 1220 bytes (3%) of program storage space. Maximum is 32256 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xe5
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xe5
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xe5
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xe5
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xe5
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xe5
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xe5
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xe5
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xe5
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xe5
Also, I noticed that the L LED won't flash when I reset the board.
The RX LED flashes from time to time when trying to upload.
PLEASE HELP
I could also mean that your Arduino is defected. Check with a meter to see if it is getting enough power.
I was having a similar issue: Cannot upload to board - Avrdude, stk500, Bootloader issues - Arduino Forum
Does your board pass the loopback test?
yes
No
I went to the link in the post and asked some questions. Please answer them.
Looks like there is no working bootloader. Flashing L at reset is its vital sign. At the same time, if the Rx blinks occasionally at uploading it means that the prompt for programming is passing to the MCU, so the Rx line looks good at least. I am little bit confused by response but could be caused by floating Tx end (?).
I would start by bootloading. However, you need some ISP programmer: another Arduino, USBasp...
The TX doesn't light at all.
Sure, if there is nothing that would respond to the prompt.
It is able to check both, rx and tx lines by loop-back test (here on web is a guide). However, it is not needed at this point.
The bootloader, this is the problem for now.
UPDATE: I just found out that it was just the UNO. I finally programmed it with another UNO. Now it has a sketch that makes it set most of it's pins to the digital value that it reads from pin A0. The new board sends the signal with pin 13 as an output. Now when they turn on, they both flash their L LEDs. The old board also flashes a bunch of other lights, (if connected). :slight_smile:
