Fixing Error compiling for Arduino Uno
hi I am having a hard time trying to understand this error message, it says missing library, but i Am unsure which library to reinstall. I have tried to reinstall the arduino agent, I havve also tried using the online version of arduno create, but the same error message appeared.. this is the error message "Arduino: 1.8.19 (Mac OS X), Board: "Arduino Uno"
fork/exec /Users/AryanGorai/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++: no such file or directory
Error compiling for board Arduino Uno.
option enabled in File -> Preferences.
the code:
#include <SPI.h>
#include <Ethernet.h>
const int SENSOR_PIN = 8;
int lastState = LOW;      // the previous state from the input pin
int currentState;         // the current reading from the input pin
int temp;
int temp1;
int pintemp = A1;
char mystring[] = "The sensor is being touched";
int buttonPin = 2;
int buttonState = 0;
int buttonPin1 = 4;
int buttonState1 = 0;
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xEF, 0xED};
EthernetServer server (80);
String readString;
Ethernet.begin(mac);
server.begin();
Serial.print("Server is at ");
Serial.println(Ethernet.localIP());
pinMode(SENSOR_PIN, INPUT);
pinMode(pintemp, INPUT);
pinMode(buttonPin, INPUT);
pinMode(buttonPin1, INPUT);
  int temp = analogRead(pintemp);    //Read the analog pin
  temp = temp * 0.48828125;   // convert output (mv) to readable celcius
  Serial.print("Temperature: ");
  Serial.print(temp);
  Serial.println("C");  //print the temperature status
  temp = temp1;
buttonState = digitalRead(buttonPin);
buttonState1 = digitalRead(buttonPin1);
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.print(c);
        readString += c;
        if (c = '\n') {
          Serial.print(readString);
          client.println("< HTTP / 1.1 200 OK >");
          client.print("<Connection-Type: text/html>");
          client.println("<Connection: close>");
          client.println("");
          client.println("<!DOCTYPE html>");
          client.println("<html>");
          client.println("<head>");
          client.println("<title>HTML Website for Arduino!</title>");
          client.println("<h1 style=text-align:center>HTML Website for Arduino!</h1>");
          client.println("<body>");
          client.println("<body style='background-color:powderblue;'>");
          client.println("<p></p>");
          if (currentState == 1){
          client.println("<p>The sensor is being touched!</p>");
          if (currentState == 0){
          client.println("<p>The sensor is not being touched!</p>");
          if (buttonState == HIGH) {
            client.println("<p>The red button is being pressed!</p>");
          if (buttonState == LOW) {
            client.println("<p>The red button is not being pressed!</p>");
          if (buttonState1 == HIGH) {
            client.println("<p>The yellow button is being pressed!</p>");
          if (buttonState1 == LOW) {
            client.println("<p>The yellow button is not being pressed!</p>");
          client.println("<a href=\"/?button1on\"\"><button>Check last button pressed!</button></a>");
          client.println("<a href=\"/?button2off\"\"><button>Check Temperature!</button></a>");
          client.println("<body style=background-colour:powderblue>");
          delay(1);
          client.stop();
          if (readString.indexOf ("?button1on") > 0)  {
            Serial.println("LED on");
          if (readString.indexOf ("?button2off") > 0)  {
          currentState = digitalRead(SENSOR_PIN);
          if(lastState == LOW && currentState == HIGH)
          Serial.println("The sensor is being touched");
          lastState = currentState;
Please do not post pictures of code. Post the full sketch in code tags along with the full error message, also in code tags, and details of the Arduino board that you are using
Your topic was MOVED to its current forum category as it is more suitable than the original
Sorry, I have updated the forum question with the right code and error messages in code format now..
It compiles OK for me, also using 1.8.19 on Mac OS X 12.4. I suspect your Arduino installation got damaged. The most reliable way to fix it is to re-install the whole IDE.
Note: There is a compiler warning about this line:
        if (c = '\n')
It should almost certainly be:
        if (c == '\n')
4 posts were split to a new topic: Error: no such file or directory
@Aryan-Gorai,
Your topic was moved by @UKHeliBob to programming questions, why did you move it back to installation and troubleshooting? This is a programming question, please leave it there.
It's not a library in the sense of "Arduino library". Your installation is missing the compiler (avr-gcc++). I'm not a Mac user so can't quite advise.
  1. When you re-installed, did you delete the directory /Users/AryanGorai/Library/Arduino15 before re-installing? That would be the first thing to do.
  2. The download of the IDE might be corrupt in some way; download it again and retry.
HMm How would i delete the directory.. Yes I have tried. multipiple times deleing and reinstalling the ide, however it does not seem to fix the issue. Pls advise me on how to delete the directory and I will try again.. thanks
