I need to display the temperature in a cooled space for a school project. This has to be done using an arduino uno and an i²c display. I found a code that supported this layout here: Measure temperature/humidity using DHT11 + LCD i2c + Arduino – SURTR TECHNOLOGY
The way everything is hooked up seems fine. There are some serious flaws to the code though.
Anybody wiling to help me out?
//This code is to use with DHT11 Temperature/humidity sensor with LCD i2c screen
//We measure the values of the temperature and humidity then print them on the screen every second
//Refer to Surtrtech channel on youtube or blogger for more information or how to use the LCD i2c
#include <dht.h> //DHT and LCD libraries
#define I2C_ADDR 0x27
#define BACKLIGHT_PIN 3
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
dht DHT; //Declaring the DHT as a dht type to use it later
#define DHT11_PIN 7 //Declaring where the DHT signal pin is wired
void setup(){
lcd.begin (16,2);
lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
lcd.setBacklight(HIGH);
lcd.home ();
lcd.clear();
lcd.setCursor(0,0);
int chk = DHT.read11(DHT11_PIN); //Reading data from the module
lcd.print("Temp: ");
lcd.print(DHT.temperature); //Showing temperature value (before that you can do some math to get the temperature in Farnheit)
lcd.print(" C");
lcd.setCursor(0,1);
lcd.print("Humidity: ");
lcd.println(DHT.humidity); //Showing humidity percentage
lcd.print(" %");
delay(1000); //Refreshing every 1s
Thanks.
