fixing the baseline zero position of a DC motor with encoder
Hello,
I am very new to arduino.
Please help me with fixing the baseline zero position of a DC motor.
I am doing it through I2C pogrammig with arduino using SDA & SCL.
motor: rhino RMCS -2201
Encoder: 0.2deg resolution optical encoder integrated on motor output shaft
supports UART/I2C/PPM/Analog signals directly for absolute speed and absolute position control
with this code we are able to control the direction and speed, but not the position.
Please guide me on the following problem:
If we have to move the motor from 0-60 degree and if for some reason it is stopped at 30 degree…
so, whenever it will start for the next time will it take the 30 degree as zero degree (as it has no any memory and has a continuous 360 degree rotation ) and move til 90 degree considering it as 0-60 degree??
Is it possible that it first comes to zero degree (from wherever it has stopped the last time) and then start moving from there itself?
Is there some way to set the encoder at the very start of the code to fix the baseline??
Please guide us.
#include <Wire.h>
#define Motor_1 0X08
signed int z;
int M_speed=255;
int in_deg=0;
int fn_deg=700;
  Wire.begin();
  i2cSendSignedInt(Motor_1, M_speed, 0);			//set the maxspeed (0) to 100
  delay(10);					        //give a 100ms delay to process the command
  i2cSendSignedLong(Motor_1, in_deg, 3);			//set the encoder counter (3) to 0
  Serial.println("Motor_1");                              // Serial print Motor_1
  i2cSendSignedLong(Motor_1, fn_deg, 4);		                //set the absolute go to posuition (4) to 1800 counts
  i2cReadSignedInt(Motor_1, 3);                           // Read the Encoder Position.
  while (z <= 700)                                       // wait till Motor_1 reaches its position
    delay(10);
    Serial.println(z);
  delay(2000);
  i2cSendSignedLong(Motor_1, fn_deg, 3);     //set the encoder counter (3) to 0
  Serial.println("Anti Clockwisse");                              // Serial print Motor_1
  i2cSendSignedLong(Motor_1, in_deg, 4);                   //set the absolute go to posuition (4) to 1800 counts
  while (z >= 0)                                       // wait till Motor_1 reaches its position
    delay(10);
    Serial.println(z);
delay(2000);
void i2cSendSignedInt(signed int SlaveAdd , signed int value, unsigned char command)
  Wire.beginTransmission(SlaveAdd);
  Wire.write(command);
  Wire.write(value & 0xFF);
  Wire.write(value >> 8);
  Wire.endTransmission();
void i2cSendSignedLong(signed int SlaveAdd, signed int value, unsigned char command)
  Wire.write(0);
  Wire.write(0);
void i2cReadSignedInt(signed int SlaveAdd, unsigned char command)
  Wire.requestFrom(SlaveAdd, 2);
  while (Wire.available())
    z = Wire.read();
    z += Wire.read() * 256;
