I am using a trinket that sends a high/low signal to a teensy 3.2 to initiate another program running. If the teensy see's a HIGH the program will start running.
I can get the trinket to send the HIGH but for some reason can't get it to revert back to LOW after 1 second. I'm leaving 1 second just to ensure the signal isn't missed.
I know I am making a very basic mistake, but hoping someone can correct me.
Thanks
Trinket code:
//#define sensor A2; // GPIO digital pin #2 = A1
#define sensorPin 2 //pin2 = A1 ... type analogRead(1)
#define ledPin 1 //PWM on 0 1 4
#define sendPin 4
int startDuration = 3000;
int startScene = 0;
int startFlag = 0;
unsigned long startTime;
unsigned long prevTime;
unsigned long prevTime2;
unsigned long prevTime3 = 0;
int ledFastActive = 0;
pinMode(sensorPin, INPUT); //analog
pinMode(ledPin, OUTPUT); //analog
pinMode(sendPin, OUTPUT); //send to teensy
analogWrite(ledPin, 255);
digitalWrite(sendPin, LOW);
checkSensor(startScene);
if (startScene == 1){
digitalWrite(sendPin, HIGH);
// else {
// digitalWrite(sendPin, LOW);
//// Serial.println("SendPin LOW");
// if ( (startScene == 0) && (digitalRead(sendPin) == 1) ) {
// if ( (millis() - prevTime3) >= 1000) {
// prevTime3 = 1000;
int checkSensor(int result) {
//LED Pulse
if (ledFastActive = 0) { // solid if sensor not triggered
int distance = analogRead(1);
int sampleDuration = 50;
if ((distance >= 250) && (startFlag == 0)) { // if sensor covered, start timer
startFlag = 1;
prevTime = millis();
prevTime2 = millis();
if ((startFlag == 1) && ((millis() - prevTime) >= sampleDuration) ) { // keep sampling 10x/sec
prevTime = prevTime + sampleDuration;
// Serial.println("Sampling: Continue holding hand over sensor");
//LED Pulse ACTIVE
ledFastActive = 1;
unsigned long now = millis();
int ledFastPeriod = 600;
int val = 128 + 127 * cos(2 * PI / ledFastPeriod * now);
analogWrite(ledPin, val);
if (distance < 250) { // cancel
startFlag = 0; // pin went low
ledFastActive = 0;
result = 0;
// Serial.println("Hand moved away!");
return result;
if ( ((millis() - prevTime2) >= startDuration) && (distance >= 250) ) { // TRIGGER
result = 1;
startFlag = 0;
prevTime = millis(); //reset clock
prevTime2 = millis(); //reset clock ??
// Serial.println("START MOTORS!");
return result;
Listening program temp code:
pinMode(6, INPUT);
pinMode(LED_BUILTIN, OUTPUT);
int val = digitalRead(7);
if (val == 1){
digitalWrite(LED_BUILTIN, HIGH);
Serial.println("Val = 1");
else{
digitalWrite(LED_BUILTIN, LOW);
Serial.println(val);
