Flame sensor giving false trigger under sun, what to do
Put a hat on the sensor to shade it from the sun.
Sun = big ball of FIRE. That are no false triggers you see.
use it only at night.
Use some sort of light detector and use the light detector value as a reference signal that is exceeded.
If you are going to use a hat, do not use a Jimmy hat.
My immediate thought is to create some code that will separate a "flickering" light from a constant light.
However you have provided No information as to what your goal is and how you are currently sensing it (i.e. sensor, processor, schematic etc)
Also you should do a mind experiment:
- Try to put all you know about your project out of mind.
- Go back and read your post and think about how others might understand your project with only that one line you posted.
JohnRob
Thsre is a sticky post named "how to use this forum-please read". It has some good advice on what makes a good question. I suggest that you read it.
