Hi Everyone,
I'm trying to get Arduino and Flash to communicate with eachother using AS3Glue and Tinkerproxy on Vista 32-bit. I'm going by this tutorial at: protolab / TutorialFlashSetup2009
I couldn't get serial proxy working, so I had to use Tinkerproxy. I uploaded Firmata to the board and I am able to connect and the swf ways 'Socket connected!', but I can't seen to send or receive data.
If anyone knows how to get all of this working, please message me. I need your help!
What happens is that it appears to succesfully connect:
serproxy says (as soon as I launch the flash): Server Thread Started server(2) - thread started
However, the Flash animation appears to not receive any data from the Arduino. The port and localhost adres are correct (127.0.0.1 and 5332) because if I change it in Flash, it doesnt even bring serproxy further than 'Waiting for clients'.
Also, Arduino does work since if I unplug it serproxy says: "Failed to open comm port - connection refused".
Ports are opened in Windows' Firewall and I also run Vista 32bit.
I also tried running TinkerProxy with port 5332, port 2 and 9600bits
Any help is greatly appreciated.
EDIT: Oops, my bad, uploaded the wrong program to the Arduino :-?. Forget about my question. Or might this be your problem as well : ? (highly unlikely but ok)
