Dear all,
Since some time I'm working a project called the 'micromouse', where the goal is (simply said) building a small robot that should solve a maze and find the shortest path.
I'm using the ItsyBitsy M4, only it doesn't have EEPROM. Most of the people solve this by using Flash As EEPROM. I found a library in order to do that, however I'm have difficulties using it. This is the link to the library: GitHub - cmaglie/FlashStorage: A convenient way to store data into Flash memory on the ATSAMD21 and ATSAMD51 processor family. Right now I've included the FlashAsEEPROM in my project, but I come across some strange errors.
Compiling 'micromouse' for 'Adafruit ItsyBitsy M4 (SAMD51)'
FlashStorage.cpp: In member function void FlashClass::write(const volatile void*, const void*, uint32_t)
FlashStorage.cpp: 56:22: error: 'volatile struct NVMCTRL_CTRLB_Type::<anonymous>' has no member named 'MANW
NVMCTRL->CTRLB.bit.MANW = 1
FlashStorage.cpp: 61:26: error: 'NVMCTRL_CTRLA_CMDEX_KEY' was not declared in this scope
Error compiling libraries
NVMCTRL->CTRLA.reg = NVMCTRL_CTRLA_CMDEX_KEY | NVMCTRL_CTRLA_CMD_PBC
Build failed for project 'micromouse'
FlashStorage.cpp: 61:52: error: 'NVMCTRL_CTRLA_CMD_PBC' was not declared in this scope
FlashStorage.cpp: 62:33: error: 'volatile struct NVMCTRL_INTFLAG_Type::<anonymous>' has no member named 'READY
while (NVMCTRL->INTFLAG.bit.READY == 0) { }
FlashStorage.cpp: 74:52: error: 'NVMCTRL_CTRLA_CMD_WP' was not declared in this scope
NVMCTRL->CTRLA.reg = NVMCTRL_CTRLA_CMDEX_KEY | NVMCTRL_CTRLA_CMD_WP
FlashStorage.cpp: 75:33: error: 'volatile struct NVMCTRL_INTFLAG_Type::<anonymous>' has no member named 'READY
FlashStorage.cpp: In member function void FlashClass::erase(const volatile void*)
FlashStorage.cpp: 93:24: error: 'NVMCTRL_CTRLA_CMDEX_KEY' was not declared in this scope
NVMCTRL->CTRLA.reg = NVMCTRL_CTRLA_CMDEX_KEY | NVMCTRL_CTRLA_CMD_ER
FlashStorage.cpp: 93:50: error: 'NVMCTRL_CTRLA_CMD_ER' was not declared in this scope
FlashStorage.cpp: 94:32: error: 'volatile struct NVMCTRL_INTFLAG_Type::<anonymous>' has no member named 'READY
while (!NVMCTRL->INTFLAG.bit.READY) { }
Does anyone know what could possibly be going wrong? If it's necessary I will post my main code where I include the library as well, however I don't see the point of it since the problem (as I see it) is most likely in the library itself.
