"FLASH overflowed by 34056 bytes"
Hi everybody
I´ve tried to make the Arduino log the data from an MPU6050 to an SD card but I ran into a problem and can't find the solution?
I use a:
MKR wifi 1010
MPU6050
ethernet shield for MKR gsm series*
The error message:
"region `FLASH' overflowed by 34056 bytes
collect2: error: ld returned 1 exit status
exit status 1"
the code:
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
File dataFile;
const int chipSelect = 4;
const int MPU=0x68;
int16_t AcX,AcY,AcZ,Tmp,GyX,GyY,GyZ;
   while (!Serial) {
    Serial.print("Initializing SD card...");
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    while (1);
  Serial.println("card initialized.");
  Wire.begin();
  Wire.beginTransmission(MPU);
  Wire.write(0x6B);
  Wire.write(0);
  Wire.endTransmission(true);
  delay(1500);
    String dataString = "";
     dataFile = SD.open("datalog.txt", FILE_WRITE);
  if (dataFile) {
    dataFile.println("Accelerometer: ");
    dataFile.println("X = "); dataFile.println(AcX);
    dataFile.println(" | Y = "); dataFile.print(AcY);
    dataFile.println(" | Z = "); dataFile.println(AcZ);
    dataFile.println("Gyroscope: ");
    dataFile.println("X = ");    dataFile.println(GyX);
    dataFile.println(" | Y = "); dataFile.println(GyY);
    dataFile.println(" | Z = "); dataFile.println(GyZ);
    dataFile.println(" ");
    delay(333);
  else {
    Serial.println("error opening datalog.txt");
  Wire.write(0x3B);
  Wire.endTransmission(false);
  Wire.requestFrom(MPU,12,true);
  AcX=Wire.read()<<8|Wire.read();
  AcY=Wire.read()<<8|Wire.read();
  AcZ=Wire.read()<<8|Wire.read();
  GyX=Wire.read()<<8|Wire.read();
  GyY=Wire.read()<<8|Wire.read();
  GyZ=Wire.read()<<8|Wire.read();
  Serial.println("Accelerometer: ");
  Serial.println("X = "); Serial.println(AcX);
  Serial.println(" | Y = "); Serial.print(AcY);
  Serial.println(" | Z = "); Serial.println(AcZ);
  Serial.println("Gyroscope: ");
  Serial.println("X = "); Serial.println(GyX);
  Serial.println(" | Y = "); Serial.println(GyY);
  Serial.println(" | Z = "); Serial.println(GyZ);
  Serial.println(" ");
  delay(333);
plz, help...
You don't close() the file anywhere.
but I have tried adding the close bracket but it still prints the error...
Get rid of the "/*" at the top.
Your code for reading the accel/gyro is inside the ELSE...meaning that it only reads those if it doesn't open the data file.
I´ve moved the accel/gyro inside the if statement and removed the "/*" but still shows the same error...
Post your entire code and the entire error message(s).
I solved the problem. But thanks for your time!
