`FLASH' overflowed by 50616 bytes - VL53L8CX sensor with Nucleo-64 Board
I'm a beginner and I've been getting this error though I removed unnecessary library files and optimized the code to minimum.
#include <Arduino.h>
#include <Wire.h>
#include <vl53l8cx_class.h>
#define SerialPort Serial
#define LPN_PIN A3
#define I2C_RST_PIN -1
#define PWREN_PIN 11
void print_result(VL53L8CX_ResultsData *Result);
void handle_cmd(uint8_t cmd);
void display_commands_banner(void);
VL53L8CX sensor_vl53l8cx_top(&Wire, LPN_PIN, I2C_RST_PIN);
uint8_t res = VL53L8CX_RESOLUTION_4X4;
  pinMode(PWREN_PIN, OUTPUT);
  digitalWrite(PWREN_PIN, HIGH);
  delay(10);
  SerialPort.begin(460800);
  Wire.begin();
  sensor_vl53l8cx_top.begin();
  sensor_vl53l8cx_top.init_sensor();
  sensor_vl53l8cx_top.vl53l8cx_start_ranging();
  VL53L8CX_ResultsData Results;
  uint8_t NewDataReady = 0;
  uint8_t status;
  do {
    status = sensor_vl53l8cx_top.vl53l8cx_check_data_ready(&NewDataReady);
  } while (!NewDataReady);
  if ((!status) && (NewDataReady != 0)) {
    status = sensor_vl53l8cx_top.vl53l8cx_get_ranging_data(&Results);
    print_result(&Results);
  if (Serial.available()>0) {
    handle_cmd(Serial.read());
  delay(100);
void print_result(VL53L8CX_ResultsData *Result) {
  // Printing results function remains the same
void toggle_resolution(void) {
  sensor_vl53l8cx_top.vl53l8cx_stop_ranging();
  switch (res) {
    case VL53L8CX_RESOLUTION_4X4:
      res = VL53L8CX_RESOLUTION_8X8;
    case VL53L8CX_RESOLUTION_8X8:
    default:
  sensor_vl53l8cx_top.vl53l8cx_set_resolution(res);
void toggle_signal_and_ambient(void) {
  // Toggle signal and ambient functionality remains the same
void clear_screen(void) {
  // Clearing screen function remains the same
void display_commands_banner(void) {
  // Displaying commands banner function remains the same
void handle_cmd(uint8_t cmd) {
  // Handling commands function remains the same
````Use code tags to format code for the forum`
