Hi All,
I need a bit of help with this code, at the moment I am trying to write a program to count the number of pulses from a Linac (one of these [Radiation Therapy | Products | Linear Accelerators | Elekta](https://Elekta Linac)) and when it has outputted the right amount of pulses it will trigger and stop the Linac. The code is not yet complete, however it does operate. There are two problems I need help with,
when I select the pulse counter ( void setPulsetriggervalue() )
and move the slider left to right it works fine, but when you go right to left the number count seems to go wrong when you get to the left hand side again. -
when using the oscilloscope function ( void Oscilloscope() ), it will display a wave form ok, but when you exit the screen using the back to main menu button , it goes to the main menu again and overwrites the main menu with what appears to be the last remains of the oscilloscope signal.
I am using a ILI9341 screen with a Arduino Mega and a mega shield.
I have yet to install a sub menu on to the pulse counter option but will do this after sorting out these problems
[table][tr][td][size=14pt][sub]Code:[/sub][/size][hr][/td][/tr][tr][td][size=9pt][tt]#include <UTFT.h>
#include <URTouch.h>
//==== Creating Objects
UTFT myGLCD(ILI9341_16, 38, 39, 40, 41);
URTouch myTouch( 6, 5, 4, 3, 2);
//==== Defining Variables
char buf[24];
int x, y;
int Input = 0;
byte Sample[320];
byte OldSample[320];
int StartSample = 0;
int EndSample = 0;
int Max = 100;
int Min = 100;
int dTime = .25;
int SampleSize = 0;
int SampleTime = 0;
int dgvh;
int hpos = 50; //set 0v on horizontal grid
int vsens = 4; // vertical sensitivity
bool scope = false;
// Define various ADC prescaler
const unsigned char PS_16 = (1 << ADPS2);
const unsigned char PS_32 = (1 << ADPS2) | (1 << ADPS0);
const unsigned char PS_64 = (1 << ADPS2) | (1 << ADPS1);
const unsigned char PS_128 = (1 << ADPS2) | (1 << ADPS1) | (1 << ADPS0);
extern uint8_t SmallFont[];
extern uint8_t BigFont[];
extern uint8_t SevenSegNumFont[];
char currentPage;
long duration;
int xTrigger = 38;
void setupcolor=#000000[/color] {
// Initial setup
myGLCD.InitLCDcolor=#000000[/color];
myGLCD.clrScrcolor=#000000[/color];
myTouch.InitTouchcolor=#000000[/color];
myTouch.setPrecisioncolor=#000000[/color];
drawHomeScreencolor=#000000[/color]; // Draws the Home Screen
// Defining Pin Modes
currentPage = '0'; // Indicates that we are at Home Screen
pinMode(0, INPUT);
// set up the ADC
ADCSRA &= ~PS_128; // remove bits set by Arduino library
// you can choose a prescaler from below.
// PS_16, PS_32, PS_64 or PS_128
ADCSRA |= PS_64; // set our own prescaler
// ====== Custom Funtions ======
// drawHomeScreen - Custom Function
void drawHomeScreencolor=#000000[/color] {
// Title
scope = false;
myGLCD.setBackColor(0, 0, 0); // Sets the background color of the area where the text will be printed to black
myGLCD.setColor(255, 255, 255); // Sets color to white
myGLCD.setFontcolor=#000000[/color]; // Sets font to big
myGLCD.print("Flash Radiotherapy", CENTER, 10); // Prints the string on the screen
myGLCD.print("Utility", CENTER, 30);
myGLCD.setColor(255, 0, 0); // Sets color to red
myGLCD.drawLine(0, 55, 319, 55); // Draws the red line
myGLCD.setFontcolor=#000000[/color]; // Sets the font to small
myGLCD.print("By Steve Horton", CENTER, 60);
myGLCD.print("Select Option", CENTER, 80);
// Button - Oscilloscope
myGLCD.setColor(16, 167, 103); // Sets green color
myGLCD.fillRoundRect (20, 110, 300, 155); // Draws filled rounded rectangle
myGLCD.drawRoundRect (20, 110, 300, 155); // Draws rounded rectangle without a fill, so the overall appearance of the button looks like it has a frame
myGLCD.setFontcolor=#000000[/color]; // Sets the font to big
myGLCD.setBackColor(16, 167, 103); // Sets the background color of the area where the text will be printed to green, same as the button
myGLCD.print("Oscilloscope", CENTER, 125); // Prints the string
// Button - Pulse counter
myGLCD.fillRoundRect (20, 175, 300, 220);
myGLCD.drawRoundRect (20, 175, 300, 220);
myGLCD.print("Pulse Counter", CENTER, 190);
void DrawGridcolor=#000000[/color]
{ myGLCD.setColor( 0, 200, 0);
for ( dgvh = 0; dgvh < 5; dgvh ++) {
myGLCD.drawLine( dgvh * 50, 0, dgvh * 50, 240);
myGLCD.drawLine( 0, dgvh * 50, 245 , dgvh * 50);
myGLCD.drawLine( 245, 0, 245, 240);
myGLCD.drawLine( 0, 239, 245, 239);
myGLCD.drawRoundRect (250, 1, 310, 50);
//-------touchscreen position sub
void touchcolor=#000000[/color] {
while color=#000000[/color]
myTouch.readcolor=#000000[/color];
x = myTouch.getXcolor=#000000[/color];
y = myTouch.getYcolor=#000000[/color];
if ((y >= 1) && (y <= 50) ) //Return to home screen button
{ if ((x >= 250) && (x <= 300) && scope == true)
{ scope = false;
currentPage = '0';
[color=#000000]}[/color]
// Highlights the button when pressed
void drawFrame(int x1, int y1, int x2, int y2) {
myGLCD.drawRoundRect (x1, y1, x2, y2);
void buttonscolor=#000000[/color] {
myGLCD.setColor(0, 0, 255);
myGLCD.fillRoundRect (250, 1, 310, 50);
void Oscilloscopecolor=#000000[/color] {
buttonscolor=#000000[/color];
while (scope == true) {
DrawGridcolor=#000000[/color];
touchcolor=#000000[/color];
[color=#434f54]// Collect the analog data into an array[/color]
[color=#000000]StartSample[/color] [color=#434f54]=[/color] [color=#d35400]micros[/color][color=#000000]([/color][color=#000000])[/color][color=#000000];[/color]
[color=#5e6d03]for[/color] [color=#000000]([/color] [color=#00979c]int[/color] [color=#000000]xpos[/color] [color=#434f54]=[/color] [color=#000000]0[/color][color=#000000];[/color]
[color=#000000]xpos[/color] [color=#434f54]<[/color] [color=#000000]240[/color][color=#000000];[/color] [color=#000000]xpos[/color] [color=#434f54]++[/color][color=#000000])[/color] [color=#000000]{[/color]
[color=#000000]Sample[/color][color=#000000][[/color] [color=#000000]xpos[/color][color=#000000]][/color] [color=#434f54]=[/color] [color=#d35400]analogRead[/color][color=#000000]([/color][color=#000000]A0[/color][color=#000000])[/color] [color=#434f54]*[/color] [color=#000000]5[/color] [color=#434f54]/[/color] [color=#000000]102[/color][color=#000000];[/color]
[color=#d35400]delayMicroseconds[/color][color=#000000]([/color][color=#000000]dTime[/color][color=#000000])[/color][color=#000000];[/color]
[color=#000000]EndSample[/color] [color=#434f54]=[/color] [color=#d35400]micros[/color][color=#000000]([/color][color=#000000])[/color][color=#000000];[/color]
[color=#434f54]// Display the collected analog data from array[/color]
[color=#5e6d03]for[/color] [color=#000000]([/color] [color=#00979c]int[/color] [color=#000000]xpos[/color] [color=#434f54]=[/color] [color=#000000]0[/color][color=#000000];[/color] [color=#000000]xpos[/color] [color=#434f54]<[/color] [color=#000000]239[/color][color=#000000];[/color]
[color=#434f54]// Erase previous display[/color]
[color=#000000]myGLCD[/color][color=#434f54].[/color][color=#d35400]setColor[/color][color=#000000]([/color] [color=#000000]0[/color][color=#434f54],[/color] [color=#000000]0[/color][color=#434f54],[/color] [color=#000000]0[/color][color=#000000])[/color][color=#000000];[/color]
[color=#000000]myGLCD[/color][color=#434f54].[/color][color=#d35400]drawLine[/color] [color=#000000]([/color][color=#000000]xpos[/color] [color=#434f54]+[/color] [color=#000000]1[/color][color=#434f54],[/color] [color=#000000]255[/color] [color=#434f54]-[/color] [color=#000000]OldSample[/color][color=#000000][[/color] [color=#000000]xpos[/color] [color=#434f54]+[/color] [color=#000000]1[/color][color=#000000]][/color][color=#434f54]*[/color] [color=#000000]vsens[/color] [color=#434f54]-[/color] [color=#000000]hpos[/color][color=#434f54],[/color] [color=#000000]xpos[/color] [color=#434f54]+[/color] [color=#000000]2[/color][color=#434f54],[/color] [color=#000000]255[/color] [color=#434f54]-[/color] [color=#000000]OldSample[/color][color=#000000][[/color] [color=#000000]xpos[/color] [color=#434f54]+[/color] [color=#000000]2[/color][color=#000000]][/color][color=#434f54]*[/color] [color=#000000]vsens[/color] [color=#434f54]-[/color] [color=#000000]hpos[/color][color=#000000])[/color][color=#000000];[/color]
[color=#5e6d03]if[/color] [color=#000000]([/color][color=#000000]xpos[/color] [color=#434f54]==[/color] [color=#000000]0[/color][color=#000000])[/color] [color=#000000]myGLCD[/color][color=#434f54].[/color][color=#d35400]drawLine[/color] [color=#000000]([/color][color=#000000]xpos[/color] [color=#434f54]+[/color] [color=#000000]1[/color][color=#434f54],[/color] [color=#000000]1[/color][color=#434f54],[/color] [color=#000000]xpos[/color] [color=#434f54]+[/color] [color=#000000]1[/color][color=#434f54],[/color] [color=#000000]239[/color][color=#000000])[/color][color=#000000];[/color]
[color=#434f54]// Draw the new data[/color]
[color=#000000]myGLCD[/color][color=#434f54].[/color][color=#d35400]setColor[/color] [color=#000000]([/color][color=#000000]255[/color][color=#434f54],[/color] [color=#000000]255[/color][color=#434f54],[/color] [color=#000000]255[/color][color=#000000])[/color][color=#000000];[/color]
[color=#000000]myGLCD[/color][color=#434f54].[/color][color=#d35400]drawLine[/color] [color=#000000]([/color][color=#000000]xpos[/color][color=#434f54],[/color] [color=#000000]255[/color] [color=#434f54]-[/color] [color=#000000]Sample[/color][color=#000000][[/color] [color=#000000]xpos[/color][color=#000000]][/color][color=#434f54]*[/color] [color=#000000]vsens[/color] [color=#434f54]-[/color] [color=#000000]hpos[/color][color=#434f54],[/color] [color=#000000]xpos[/color] [color=#434f54]+[/color] [color=#000000]1[/color][color=#434f54],[/color] [color=#000000]255[/color] [color=#434f54]-[/color] [color=#000000]Sample[/color][color=#000000][[/color] [color=#000000]xpos[/color] [color=#434f54]+[/color] [color=#000000]1[/color][color=#000000]][/color][color=#434f54]*[/color] [color=#000000]vsens[/color] [color=#434f54]-[/color] [color=#000000]hpos[/color][color=#000000])[/color][color=#000000];[/color]
[color=#434f54]// Determine sample voltage peak to peak[/color]
[color=#000000]Max[/color] [color=#434f54]=[/color] [color=#000000]Sample[/color][color=#000000][[/color] [color=#000000]100[/color][color=#000000]][/color][color=#000000];[/color]
[color=#000000]Min[/color] [color=#434f54]=[/color] [color=#000000]Sample[/color][color=#000000][[/color] [color=#000000]100[/color][color=#000000]][/color][color=#000000];[/color]
[color=#000000]OldSample[/color][color=#000000][[/color] [color=#000000]xpos[/color][color=#000000]][/color] [color=#434f54]=[/color] [color=#000000]Sample[/color][color=#000000][[/color] [color=#000000]xpos[/color][color=#000000]][/color][color=#000000];[/color]
[color=#5e6d03]if[/color] [color=#000000]([/color][color=#000000]Sample[/color][color=#000000][[/color] [color=#000000]xpos[/color][color=#000000]][/color] [color=#434f54]>[/color] [color=#000000]Max[/color][color=#000000])[/color] [color=#000000]Max[/color] [color=#434f54]=[/color] [color=#000000]Sample[/color][color=#000000][[/color] [color=#000000]xpos[/color][color=#000000]][/color][color=#000000];[/color]
[color=#5e6d03]if[/color] [color=#000000]([/color][color=#000000]Sample[/color][color=#000000][[/color] [color=#000000]xpos[/color][color=#000000]][/color] [color=#434f54]<[/color] [color=#000000]Min[/color][color=#000000])[/color] [color=#000000]Min[/color] [color=#434f54]=[/color] [color=#000000]Sample[/color][color=#000000][[/color] [color=#000000]xpos[/color][color=#000000]][/color][color=#000000];[/color]
[color=#434f54]// display the sample time, delay time and trigger level[/color]
[color=#000000]myGLCD[/color][color=#434f54].[/color][color=#d35400]setBackColor[/color][color=#000000]([/color] [color=#000000]0[/color][color=#434f54],[/color] [color=#000000]0[/color][color=#434f54],[/color] [color=#000000]255[/color][color=#000000])[/color][color=#000000];[/color]
[color=#000000]myGLCD[/color][color=#434f54].[/color][color=#d35400]setFont[/color][color=#000000]([/color] [color=#000000]SmallFont[/color][color=#000000])[/color][color=#000000];[/color]
[color=#000000]myGLCD[/color][color=#434f54].[/color][color=#d35400]print[/color][color=#000000]([/color][color=#005c5f]"Return"[/color][color=#434f54],[/color] [color=#000000]260[/color][color=#434f54],[/color] [color=#000000]5[/color][color=#000000])[/color][color=#000000];[/color]
[color=#000000]myGLCD[/color][color=#434f54].[/color][color=#d35400]print[/color][color=#000000]([/color][color=#005c5f]"to Main"[/color][color=#434f54],[/color] [color=#000000]252[/color][color=#434f54],[/color] [color=#000000]20[/color][color=#000000])[/color][color=#000000];[/color]
[color=#000000]myGLCD[/color][color=#434f54].[/color][color=#d35400]print[/color][color=#000000]([/color][color=#005c5f]"Menu"[/color][color=#434f54],[/color] [color=#000000]265[/color][color=#434f54],[/color] [color=#000000]35[/color][color=#000000])[/color][color=#000000];[/color]
[color=#000000]SampleTime[/color] [color=#434f54]=[/color] [color=#000000]([/color] [color=#000000]EndSample[/color] [color=#434f54]-[/color] [color=#000000]StartSample[/color][color=#000000])[/color] [color=#434f54]/[/color] [color=#000000]1000[/color][color=#000000];[/color]
[color=#000000]myGLCD[/color][color=#434f54].[/color][color=#d35400]print[/color][color=#000000]([/color][color=#005c5f]"Sec."[/color][color=#434f54],[/color] [color=#000000]205[/color][color=#434f54],[/color] [color=#000000]210[/color][color=#000000])[/color][color=#000000];[/color]
[color=#000000]myGLCD[/color][color=#434f54].[/color][color=#d35400]print[/color][color=#000000]([/color][color=#005c5f]" "[/color][color=#434f54],[/color] [color=#000000]280[/color][color=#434f54],[/color] [color=#000000]30[/color][color=#000000])[/color][color=#000000];[/color]
[color=#000000]myGLCD[/color][color=#434f54].[/color][color=#d35400]print[/color][color=#000000]([/color][color=#000000]itoa[/color][color=#000000]([/color] [color=#000000]SampleTime[/color][color=#434f54],[/color] [color=#000000]buf[/color][color=#434f54],[/color] [color=#000000]10[/color][color=#000000])[/color][color=#434f54],[/color] [color=#000000]205[/color][color=#434f54],[/color] [color=#000000]220[/color][color=#000000])[/color][color=#000000];[/color]
[color=#434f54]// Range of 0 to 64 * 78 = 4992 mV[/color]
[color=#000000]SampleSize[/color] [color=#434f54]=[/color] [color=#000000]([/color] [color=#000000]Max[/color] [color=#434f54]-[/color] [color=#000000]Min[/color][color=#000000])[/color] [color=#434f54]*[/color] [color=#000000]78[/color][color=#000000];[/color]
[color=#000000]myGLCD[/color][color=#434f54].[/color][color=#d35400]print[/color][color=#000000]([/color][color=#005c5f]"mVolt"[/color][color=#434f54],[/color] [color=#000000]5[/color][color=#434f54],[/color] [color=#000000]210[/color][color=#000000])[/color][color=#000000];[/color]
[color=#000000]myGLCD[/color][color=#434f54].[/color][color=#d35400]print[/color][color=#000000]([/color] [color=#000000]itoa[/color][color=#000000]([/color] [color=#000000]SampleSize[/color][color=#434f54],[/color] [color=#000000]buf[/color][color=#434f54],[/color] [color=#000000]10[/color][color=#000000])[/color][color=#434f54],[/color] [color=#000000]5[/color][color=#434f54],[/color] [color=#000000]220[/color][color=#000000])[/color][color=#000000];[/color]
[color=#000000]myGLCD[/color][color=#434f54].[/color][color=#d35400]print[/color][color=#000000]([/color][color=#000000]itoa[/color][color=#000000]([/color] [color=#d35400]analogRead[/color][color=#000000]([/color][color=#000000]A0[/color][color=#000000])[/color] [color=#434f54]*[/color] [color=#000000]4.15[/color] [color=#434f54]/[/color] [color=#000000]10.23[/color][color=#434f54],[/color] [color=#000000]buf[/color][color=#434f54],[/color] [color=#000000]10[/color][color=#000000])[/color][color=#434f54],[/color] [color=#000000]110[/color] [color=#434f54],[/color] [color=#000000]220[/color][color=#000000])[/color][color=#000000];[/color]
void pulsetriggerControlcolor=#000000[/color] {//Draw pulse trigger Control screen
myGLCD.setColor(100, 155, 203);
myGLCD.fillRoundRect (10, 10, 60, 36);
myGLCD.drawRoundRect (10, 10, 60, 36);
myGLCD.setBackColor(100, 155, 203);
myGLCD.print("<-", 18, 15);
myGLCD.print("Back to Main Menu", 70, 18);
myGLCD.print("Trigger pulse", CENTER, 45);
myGLCD.print("Control", CENTER, 65);
myGLCD.print("Select Trigger", CENTER, 95);
myGLCD.print("point", CENTER, 110);
myGLCD.drawLine(0, 87, 319, 87);
myGLCD.drawRect(30, 138, 310, 148); // Pulse trigger Slider
//============= se// Maps the values of the X - Axis from 38 to 0 and 310 to 1024, because we need values from 0 to 255 for turning on the ledtPulsetriggervalue() - Custom Funtion
void setPulsetriggervaluecolor=#000000[/color] {
if color=#000000[/color] {
// Area of the xTrigger slider
if ( (y >= 130) && (y <= 156)) {
xTrigger = x; // Stores the X value where the screen has been pressed in to variable xR
if (xTrigger <= 38) { // Confines the area of the slider to be above 38 pixels
xTrigger = 38;
if (xTrigger >= 303) { /// Confines the area of the slider to be under 310 pixels
xTrigger = 303;
//values from 0 to 1024 for setting the value at which we trigger the PRF check
int long xTriggercount = map(xTrigger, 38, 310, 0, 1024);
myGLCD.print( itoa( xTriggercount, buf, 10), 5, 180);
// Draws the positioner for trigger pulse
myGLCD.fillRect(xTrigger, 139, (xTrigger + 4), 147); // Positioner
myGLCD.setColor(xTriggercount, 0, 0);
myGLCD.fillRect(31, 139, (xTrigger - 1), 147);
myGLCD.setColor(0, 0, 0);
myGLCD.fillRect((xTrigger + 5), 139, 309, 147);
void loopcolor=#000000[/color] {
// Home Screen
if (currentPage == '0') {
scope = false;
x = myTouch.getXcolor=#000000[/color]; // X coordinate where the screen has been pressed
y = myTouch.getYcolor=#000000[/color]; // Y coordinates where the screen has been pressed
// If we press the Distance Sensor Button
if ((x >= 20) && (x <= 300) && (y >= 110) && (y <= 155)) {
drawFrame(20, 110, 300, 155); // Custom Function -Highlighs the buttons when it's pressed
currentPage = '1'; // Indicates that we are the first example
myGLCD.clrScrcolor=#000000[/color]; // Clears the screen
scope = true;
Oscilloscopecolor=#000000[/color]; // It is called only once, because in the next iteration of the loop, this above if statement will be false so this funtion won't be called. This function will draw the graphics of the first example.
// If we press the Pulse counter button
if ((x >= 20) && (x <= 300) && (y >= 175) && (y <= 220)) {
drawFrame(20, 175, 300, 220);
currentPage = '2';
pulsetriggerControlcolor=#000000[/color];
// pulsetriggerControl
if (currentPage == '2') {
setPulsetriggervaluecolor=#000000[/color];
[color=#434f54]//Back button[/color]
[color=#5e6d03]if[/color] [color=#000000]([/color][color=#000000]([/color][color=#000000]x[/color] [color=#434f54]>=[/color] [color=#000000]10[/color][color=#000000])[/color] [color=#434f54]&&[/color] [color=#000000]([/color][color=#000000]x[/color] [color=#434f54]<=[/color] [color=#000000]60[/color][color=#000000])[/color] [color=#434f54]&&[/color] [color=#000000]([/color][color=#000000]y[/color] [color=#434f54]>=[/color] [color=#000000]10[/color][color=#000000])[/color] [color=#434f54]&&[/color] [color=#000000]([/color][color=#000000]y[/color] [color=#434f54]<=[/color] [color=#000000]36[/color][color=#000000])[/color][color=#000000])[/color] [color=#000000]{[/color]
[color=#000000]drawFrame[/color][color=#000000]([/color][color=#000000]10[/color][color=#434f54],[/color] [color=#000000]10[/color][color=#434f54],[/color] [color=#000000]60[/color][color=#434f54],[/color] [color=#000000]36[/color][color=#000000])[/color][color=#000000];[/color]
[color=#000000]currentPage[/color] [color=#434f54]=[/color] [color=#00979c]'0'[/color][color=#000000];[/color]
[color=#000000]myGLCD[/color][color=#434f54].[/color][color=#d35400]clrScr[/color][color=#000000]([/color][color=#000000])[/color][color=#000000];[/color]
[color=#000000]drawHomeScreen[/color][color=#000000]([/color][color=#000000])[/color][color=#000000];[/color]
}[/tt][/size][/td][/tr][/table]
Any help would be greatly appreciated
Steve
[Mod edit]
@Steve_H , I appreciate that you might well have the appropriate skills to do this safely. For the benefit of anyone else reading this please be aware that there are dangers involved in this project and you should not attempt to do what Steve is doing unless you have the approprate skills to understand the risks and how to mitigate them.
Thank you.
