Flashing 3 leds together for one cycle with respect to thier input....
I have been able to get my code working, however I seem to have one issue I can't seem to overcome, I have three independent outputs driving three independent leds, so each led needs to blink with respect to the current value associated with its output. But the leds only flash one at a time and this needs to happen together.
For example: sensor1 will cause led1 to flash 5 times with output1=.50, at the same time sensor2 may have an output = to .70 in which case led2 will flash 7 times, while sensor3 will cause led3 to flash 7 times with output=.70 also.......
The problem is all three leds need to flash in sync with each other through one complete cycle so if one sensor should fail or its output not equal to the other(as in the example above) this will cause one of the leds to blink short, which will indicate an issue with the associated sensor connect to that output. I have included a copy of my current code. I hope this makes sense.
Thank you
Dave
  // include the library code:
     #include <LiquidCrystal.h>
     #define aref_voltage1 1.72
     #define PPO1 inputReading1*aref_voltage/1024
     #define PPO2 inputReading2*aref_voltage/1024
     #define PPO3 inputReading3*aref_voltage/1024
      LiquidCrystal lcd(12, 11, 5, 4, 3, 2); // initialize the lcd with the numbers of the interface pins
      const int red1      =22;
      const int blue1     =28;
      const int green1    =26;
            int nr1; // declare numbers of flashes
      const int red2      =30;
      const int blue2     =36;
      const int green2    =34;
            int nr2;
      const int red3      =38;
      const int blue3     =44;
      const int green3    =42;
            int nr3;
      const int sensor1 = A0;  // the analog pin the 02 Sensor Vout pin is connected to
            int inputReading1; //declare a variable
      const int sensor2 = A1;  // the analog pin the 02 Sensor Vout pin is connected to
            int inputReading2; // declare a variable
      const int sensor3 = A2;  // the analog pin the 02 sensor Vout pin is connected to
            int inputReading3; // declare a variable
    void setup ()
       analogReference(EXTERNAL); // set external analog Ref for PPO output
       pinMode( red1, OUTPUT);
       pinMode( green1, OUTPUT);
       pinMode( blue1, OUTPUT);
       pinMode( red2, OUTPUT);
       pinMode( green2, OUTPUT);
       pinMode( blue2, OUTPUT);
       pinMode( red3, OUTPUT);
       pinMode( green3, OUTPUT);
       pinMode( blue3, OUTPUT);
      lcd.begin(20, 4);
      lcd.setCursor(0, 0);//where to start cursor
      lcd.print("PINA SYSYTEMS       ");//print message
      lcd.print("SOFTWARE VERSION 1.0");//print message
      delay(2000);
      lcd.clear();
      lcd.setCursor(0, 0); // set the cursor to column 0, line 0
      lcd.print("PPO1");  // Print a message to the LCD.
      lcd.setCursor(6, 0); // set the cursor to column 6, line 0
      lcd.print("PPO2"); // Print a message to the LCD
      lcd.setCursor(12, 0); // set the cursor to column 12, line 0
      lcd.print("PPO3");  // Print a message to the LCD.
      void blinkGreen1(int nr1) // number of blinks follwed by a delay
         if( PPO1 <= .50)
            for(int i=0; i< nr1; i++)
            digitalWrite(green1,LOW);
            delay(250);
            digitalWrite(green1, HIGH);
            delay(250);
            else digitalWrite(green1, HIGH);
      void blinkBlue1(int nr1) // number of blinks follwed by a delay
         if( PPO1 > .50 && PPO1 < 1.00)
            digitalWrite(blue1,LOW);
            delay(250);
            digitalWrite(blue1, HIGH);
            delay(250);
            else digitalWrite(blue1, HIGH);
      void blinkRed1(int nr1) // number of blinks follwed by a delay
         if(PPO1 >1.00)
            digitalWrite(red1,LOW);
             delay(250);
            digitalWrite(red1, HIGH);
            delay(250);
            else digitalWrite(red1, HIGH);
      void blinkGreen2(int nr2) // number of blinks follwed by a delay
         if( PPO2 <= .50)
            for(int i=0; i< nr2; i++)
            digitalWrite(green2,LOW);
            delay(250);
            digitalWrite(green2, HIGH);
            delay(250);
            else digitalWrite(green2, HIGH);
      void blinkBlue2(int nr2) // number of blinks follwed by a delay
         if( PPO2 > .50 && PPO2 < 1.00)
            digitalWrite(blue2,LOW);
            delay(250);
            digitalWrite(blue2, HIGH);
            delay(250);
            else digitalWrite(blue2, HIGH);
      void blinkRed2(int nr2) // number of blinks follwed by a delay
         if(PPO2 >1.00)
            digitalWrite(red2,LOW);
             delay(250);
            digitalWrite(red2, HIGH);
            delay(250);
            else digitalWrite(red2, HIGH);
      void blinkGreen3(int nr3) // number of blinks follwed by a delay
         if( PPO3 <= .50)
            for(int i=0; i< nr3; i++)
            digitalWrite(green3,LOW);
            delay(250);
            digitalWrite(green3, HIGH);
            delay(250);
            else digitalWrite(green3, HIGH);
      void blinkBlue3(int nr3) // number of blinks follwed by a delay
         if( PPO3 > .50 && PPO3 < 1.00)
            digitalWrite(blue3,LOW);
            delay(250);
            digitalWrite(blue3, HIGH);
            delay(250);
            else digitalWrite(blue3, HIGH);
      void blinkRed3(int nr3) // number of blinks follwed by a delay
         if(PPO3 >1.00)
            digitalWrite(red3,LOW);
             delay(250);
            digitalWrite(red3, HIGH);
            delay(250);
            else digitalWrite(red3, HIGH);
     void loop ()
          blinkGreen1((int)(PPO1*10)); // flash green1
          blinkBlue1((int)(PPO1*10)); // flash blue1
          blinkRed1((int)(PPO1*10)); // flash red1
          blinkGreen2((int)(PPO2*10)); // flash green2
          blinkBlue2((int)(PPO2*10)); // flash blue2
          blinkRed2((int)(PPO2*10)); // flash red2
          blinkGreen3((int)(PPO3*10)); // flash green3
          blinkBlue3((int)(PPO3*10)); // flash blue3
          blinkRed3((int)(PPO3*10)); // flash red3
        lcd.setCursor(0, 1); //sets the cursor to column 0, line 1
        inputReading1 = analogRead(sensor1); //getting the voltage reading from the 02 sensor
        float voltage1 = inputReading1 * aref_voltage1; // converting that reading to voltage
        voltage1 /= 1024.0;
        lcd.print(voltage1, 2);//print actual voltage to lcd
        delay(200);
        lcd.setCursor(6, 1); //sets the cursor to column 6, line 1
        inputReading2 = analogRead(sensor2); //getting the voltage reading from the O2 sensor
        float voltage2 = inputReading2 * aref_voltage2; // converting that reading to voltage
        voltage2 /= 1024.0;
        lcd.print(voltage2, 2);  //print actual voltage to lcd
        delay(200);
        lcd.setCursor(12, 1); //sets the cursor to column 12, line 2
        inputReading3 = analogRead(sensor3); //getting the voltage reading from the O2 sensor
        float voltage3 = inputReading3 * aref_voltage3; // converting that reading to voltage
        voltage3 /= 1024.0;
        lcd.print(voltage3, 2);  //print actual voltage to lcd
        delay(200);
If you want two things to happen "at the same time" you can't put any delay() calls between the two things.
If you want to use delay() to time your blinks AND you want to blink more than one LED at a time you have to:
turn on ALL the LED's you want to blink this cycle.
delay();
turn off ALL the LED's you want to blink this cycle.
delay();
Because of that you can't have separate blink functions for different LED's.
johnwasser:
delay();
delay();
Perfect, thank you so much!!!! your shining alot of light on the subject....
So this is obviously not the solution....well I'm back to drawing board....
thanx john
I suggest to use interrupts to blink the LEDs. See my POV experiment Persistence of Vision | Blinkenlight for an example. The idea would be to read the sensors in the main loop and then just tell the interrupt part the desired blink pattern. Passing the data between those two parts would be done by means of "volatile" variables.
For an example how to handle the communication between an interrupt driven part and the main loop have a look at my second VU meter example (at the bottom of the page): VU Meter | Blinkenlight.
