I am currently writing software, which should be capable of flashing an Arduino 101 board. I currently try to reproduce what the IDE does by using build-arduino to build the sketch, and then running the arduino101load (which in turn uses the provided dfu-util).
They both do their jobs well, but the arduino101load utility does not detect the Arduino 101 board and hits the wait timeout if I don't push the "master reset" button on the device manually when it scans for a device.
My guess is that Arduino IDE somehow reboots the board via USB (COM port, to be precise), but how does it do it? And how can I do the same?
I'm currently using windows and mac os x, but it needs to run on linux too.
Yes, you need to "touch" the port at 1200bps to trigger a reboot in download mode.
The easiest way is to write a small program in a language without dependencies (eg golang) which opens/closes the port before trying the download. arduino101load sources are here if you want to hack them
