Im trying to simply reset a Heltec LoRa V3 with factory firmware. When I try upload to the device, I get the following errors:
C:\Users\forml\AppData\Local\Temp\.arduinoIDE-unsaved2024325-18572-1kallwi.g0st\WiFi_LoRa_32_V3_FactoryTest_V2\WiFi_LoRa_32_V3_FactoryTest_V2.ino: In function 'void intodeepsleep()':
C:\Users\forml\AppData\Local\Temp\.arduinoIDE-unsaved2024325-18572-1kallwi.g0st\WiFi_LoRa_32_V3_FactoryTest_V2\WiFi_LoRa_32_V3_FactoryTest_V2.ino:357:11: error: 'RADIO_DIO_1' was not declared in this scope
pinMode(RADIO_DIO_1,ANALOG);
C:\Users\forml\AppData\Local\Temp\.arduinoIDE-unsaved2024325-18572-1kallwi.g0st\WiFi_LoRa_32_V3_FactoryTest_V2\WiFi_LoRa_32_V3_FactoryTest_V2.ino:357:11: note: suggested alternative: 'RADIO_SET_RX'
RADIO_SET_RX
C:\Users\forml\AppData\Local\Temp\.arduinoIDE-unsaved2024325-18572-1kallwi.g0st\WiFi_LoRa_32_V3_FactoryTest_V2\WiFi_LoRa_32_V3_FactoryTest_V2.ino:358:11: error: 'RADIO_NSS' was not declared in this scope
pinMode(RADIO_NSS,ANALOG);
C:\Users\forml\AppData\Local\Temp\.arduinoIDE-unsaved2024325-18572-1kallwi.g0st\WiFi_LoRa_32_V3_FactoryTest_V2\WiFi_LoRa_32_V3_FactoryTest_V2.ino:358:11: note: suggested alternative: 'RADIO_SET_FS'
RADIO_SET_FS
C:\Users\forml\AppData\Local\Temp\.arduinoIDE-unsaved2024325-18572-1kallwi.g0st\WiFi_LoRa_32_V3_FactoryTest_V2\WiFi_LoRa_32_V3_FactoryTest_V2.ino:359:11: error: 'RADIO_RESET' was not declared in this scope
pinMode(RADIO_RESET,ANALOG);
C:\Users\forml\AppData\Local\Temp\.arduinoIDE-unsaved2024325-18572-1kallwi.g0st\WiFi_LoRa_32_V3_FactoryTest_V2\WiFi_LoRa_32_V3_FactoryTest_V2.ino:359:11: note: suggested alternative: 'RADIO_SET_TX'
RADIO_SET_TX
C:\Users\forml\AppData\Local\Temp\.arduinoIDE-unsaved2024325-18572-1kallwi.g0st\WiFi_LoRa_32_V3_FactoryTest_V2\WiFi_LoRa_32_V3_FactoryTest_V2.ino:360:11: error: 'RADIO_BUSY' was not declared in this scope
pinMode(RADIO_BUSY,ANALOG);
C:\Users\forml\AppData\Local\Temp\.arduinoIDE-unsaved2024325-18572-1kallwi.g0st\WiFi_LoRa_32_V3_FactoryTest_V2\WiFi_LoRa_32_V3_FactoryTest_V2.ino:360:11: note: suggested alternative: 'RADIO_SET_RX'
RADIO_SET_RX
C:\Users\forml\AppData\Local\Temp\.arduinoIDE-unsaved2024325-18572-1kallwi.g0st\WiFi_LoRa_32_V3_FactoryTest_V2\WiFi_LoRa_32_V3_FactoryTest_V2.ino:361:11: error: 'LORA_CLK' was not declared in this scope
pinMode(LORA_CLK,ANALOG);
C:\Users\forml\AppData\Local\Temp\.arduinoIDE-unsaved2024325-18572-1kallwi.g0st\WiFi_LoRa_32_V3_FactoryTest_V2\WiFi_LoRa_32_V3_FactoryTest_V2.ino:361:11: note: suggested alternative: 'LORA_CAD'
LORA_CAD
C:\Users\forml\AppData\Local\Temp\.arduinoIDE-unsaved2024325-18572-1kallwi.g0st\WiFi_LoRa_32_V3_FactoryTest_V2\WiFi_LoRa_32_V3_FactoryTest_V2.ino:362:11: error: 'LORA_MISO' was not declared in this scope
pinMode(LORA_MISO,ANALOG);
C:\Users\forml\AppData\Local\Temp\.arduinoIDE-unsaved2024325-18572-1kallwi.g0st\WiFi_LoRa_32_V3_FactoryTest_V2\WiFi_LoRa_32_V3_FactoryTest_V2.ino:362:11: note: suggested alternative: 'LORA_CAD'
LORA_CAD
C:\Users\forml\AppData\Local\Temp\.arduinoIDE-unsaved2024325-18572-1kallwi.g0st\WiFi_LoRa_32_V3_FactoryTest_V2\WiFi_LoRa_32_V3_FactoryTest_V2.ino:363:11: error: 'LORA_MOSI' was not declared in this scope
pinMode(LORA_MOSI,ANALOG);
C:\Users\forml\AppData\Local\Temp\.arduinoIDE-unsaved2024325-18572-1kallwi.g0st\WiFi_LoRa_32_V3_FactoryTest_V2\WiFi_LoRa_32_V3_FactoryTest_V2.ino:363:11: note: suggested alternative: 'LORA_CAD'
LORA_CAD
C:\Users\forml\AppData\Local\Temp\.arduinoIDE-unsaved2024325-18572-1kallwi.g0st\WiFi_LoRa_32_V3_FactoryTest_V2\WiFi_LoRa_32_V3_FactoryTest_V2.ino: In function 'void setup()':
C:\Users\forml\AppData\Local\Temp\.arduinoIDE-unsaved2024325-18572-1kallwi.g0st\WiFi_LoRa_32_V3_FactoryTest_V2\WiFi_LoRa_32_V3_FactoryTest_V2.ino:424:13: error: 'HELTEC_BOARD' was not declared in this scope
Mcu.begin(HELTEC_BOARD,SLOW_CLK_TPYE);
C:\Users\forml\AppData\Local\Temp\.arduinoIDE-unsaved2024325-18572-1kallwi.g0st\WiFi_LoRa_32_V3_FactoryTest_V2\WiFi_LoRa_32_V3_FactoryTest_V2.ino:424:26: error: 'SLOW_CLK_TPYE' was not declared in this scope
exit status 1
Compilation error: 'RADIO_DIO_1' was not declared in this scope
Anyone able to help out? As far as I can see, the ESP32 and Heltec libraries are installed, I did it through library manager in Arduino IDE.
Thanks,
FF
