Hi, newbie here.
I am a new linux mint 19.2 user
I have got great cow basic installed and working.
It has created a hex file for nano or uno from a gcb program file.
I have the linux arduino ide installed which includes avrdude.
If I type avrdude in the terminal I get a list of commands.
I have avrdude in /usr/bin/avrdude.
my uno is on /dev/ttyUSB0
If I have a file in /home/stan/GCBprogs/gcbfile.hex
What is the avrdude command to use to flash that hex file to a uno?
You can find out how the Arduin IDE uses avrdude by turning on verbose upload logging in Preference. For example if I upload the Blink example to an UNO I get this avrdude command line in the log:
'-C': configuration file. You may not need one.
'-v': Use verbose messages
'-p': What processor (so the processor signature can be checked)
'-c': I don't know. I think it is an upload protocol name.
'-P': The serial port to upload to.
'-b': The baud rate for the serial port
'-D': I don't know.
'-Uflash:w:HexFile.hex:i': Upload and write the Intel-format HEX file into FLASH[/code]
You should be able to use the command line 'man avrdude' to display the user manual for avrdude.
