Hi all,
I am trying to burn & boot my sketches bypassing bootloader for space and timing issues. I am using Atmega8 but I can't end up in uploading my sketch using the Arduino IDE v0007 :(
I have build and tested the parallel programmer. I have modified the three entries of the "preferences.txt" file as per documentation, installed giveio and applied reg patch. I succeeded in re-burning the bootloader using the "Tools/Burn Bootloader (parallel port)" menu, but I could not burn a sketch of mine eventually: I always end up with a "Programmer is not responding error".
However, by directly using the 'uisp' tool on command line I was able to correctly burn and run my sketch! Is there something else i need to tune in the Arduino IDE ?
thanks & regards.
David
