Flex Sensor DC Motors sketch
Hi everyone is there anything i could do about all these equal values and make my code shorter ?
also some of the code values seem to be interwined which causes my motor (MOTOR A via Sensor B) and (Motor B via Sensor B) to spin and stop contiunously
here is the code
any help is apreciated
//Motor B
int enableB = 3;
int MotorB1 = 2;
int MotorB2 = 4;
//Motor A
int enableA = 5;
int MotorA1 = 6;
int MotorA2 = 7;
//sensor
int flexValue2;
int flexValue;
const int flexPin2 = A1;
const int flexPin = A0;
//greenpin
const int greenPin = 11;
int ledState = LOW;
unsigned long previousMillis = 0;
const long interval = 1000;
Serial.begin (9600);
pinMode (enableA, OUTPUT);
pinMode (MotorA1, OUTPUT);
pinMode (MotorA2, OUTPUT);
pinMode (enableB, OUTPUT);
pinMode (MotorB1, OUTPUT);
pinMode (MotorB2, OUTPUT);
pinMode (greenPin, OUTPUT);
if (currentMillis - previousMillis >= interval) {
// save the last time you blinked the LED
// if the LED is off turn it on and vice-versa:
if (ledState == LOW) {
ledState = HIGH;
ledState = LOW;
// set the LED with the ledState of the variable:
digitalWrite(greenPin, ledState);
//enabling motor A Back Sensor
Serial.println (“Enabling MotorsA”);
digitalWrite (enableA, HIGH);
//do something
flexValue = analogRead(flexPin);
delay (0);
Serial.println(flexValue);
Serial.print("sensorB: ");
if (flexValue < 400)
Serial.println (“Motion Backwards”);
digitalWrite (MotorA1, HIGH);
digitalWrite (MotorA2, LOW);
if (flexValue == 764)
Serial.println (“Stoping motors”);
digitalWrite (MotorA1, LOW);
if (flexValue == 763)
if (flexValue == 755)
if (flexValue == 756)
if (flexValue == 757)
if (flexValue == 758)
if (flexValue == 759)
if (flexValue == 760)
if (flexValue == 761)
//MOTOR A FRONT SENSOR
//enabling motor A
//do something
flexValue2 = analogRead(flexPin2);
delay (0);
Serial.println(flexValue2);
Serial.print("sensorA: ");
if (flexValue2 > 785)
Serial.println (“Motion FORWARD”);
digitalWrite (MotorA2, HIGH);
if (flexValue2 == 777)
Serial.println (“Stop Motors”);
if (flexValue2 == 774)
if (flexValue2 == 772)
if (flexValue2 == 771)
if (flexValue2 == 773)
if (flexValue2 == 775)
if (flexValue2 == 776)
if (flexValue2 == 778)
if (flexValue2 == 779)
if (flexValue2 == 780)
if (flexValue2 == 781)
if (flexValue2 == 782)
//TOP Motor
Serial.println (“Enabling MotorsB”);
digitalWrite (enableB, HIGH);
//do something
delay (0);
digitalWrite (MotorB1, LOW);
digitalWrite (MotorB2, HIGH);
if (flexValue > 550)
digitalWrite (MotorB2, LOW);
You could certainly use || (logical or) in your ifs when outcomes are the same instead of a long string of separate ifs. E.g.
     if (flexValue2 == 777 || flexValue2 == 774 || flexValue2 == 772 || ... etc )
    Serial.println ("Stop Motors");
There are probably more examples. That would be a start in getting the code down to a more manageable size.
Steve
