When i use both flexitimer2 and tone function, either tone or the flexitimer2 isnt gets sscrewed up. may i know the reason why? and is there any alternative or any solution to solve this problem.. Thanks in advance
Do not cross-post. Other two threads removed.
the tone()
function uses timer2 and as its name implies, flexitimer2
does so too (library to use timer 2 with a configurable resolution)
to solve this you need to find an alternative to one of the 2 so that they don't rely on the same timer (there are alternatives to tone() )
J-M-L:
thetone()
function uses timer2 and as its name implies,flexitimer2
does so too (library to use timer 2 with a configurable resolution)to solve this you need to find an alternative to one of the 2 so that they don't rely on the same timer (there are alternatives to tone() )
may i know wat are the alternatives of tone function?
Alternative to tone is NewTone.
