Flickering Display Problems!
I'am using Womart's 3.2" tft touch shield: http://www.ebay.com/itm/3-2-TFT-LCD-Shield-Touch-Panel-Display-w-TF-Reader-for-Arduino-UNO-R3-A137-/261189517905?pt=LH_DefaultDomain_0&hash=item3cd01bc251
I'am having problems with flickering when I running the graphics test. When I tried another program the display was clear for a short amount of time then it turned white. Right here I'm just drawing a green square but the rest of the commented code is the actual graphics test. Does anyone have any solutions or suggestions to fix this problem?
Here's my code:
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
// you can also just connect RESET to the arduino RESET pin
#define LCD_RESET A4
//Duemilanove/Diecimila/UNO/etc ('168 and '328 chips) microcontoller:
// Color definitions
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
#include "C:\arduino-0022\TestProg\graphicstest\TFTLCD.h"
TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
void setup(void) {
Serial.println("8 Bit LCD test!");
tft.reset();
//uint16_t identifier = tft.readRegister(0x0);
// if (identifier == 0x9325)
// Serial.println("Found ILI9325");
// } else if (identifier == 0x9328)
// Serial.println("Found ILI9328");
//} else
// Serial.print("Unknown driver chip ");
// Serial.println(identifier, HEX);
// while (1);
tft.initDisplay();
/* testtext(RED);
delay(2000);
testlines(CYAN);
testfastlines(RED, BLUE);
testdrawrects(GREEN);
testfillrects(YELLOW, MAGENTA);
tft.fillScreen(BLACK);
testfillcircles(10, MAGENTA);
testdrawcircles(10, WHITE);
testtriangles();
testfilltriangles();
testRoundRect();
testFillRoundRect(); */
//testtext(RED);
void loop(void) {
// testtext(RED);
// for (uint8_t rotation=0; rotation<4; rotation++) {
//tft.setRotation(rotation);
//testtext(RED);
//delay(2000);
while (1)
//tft.initDisplay();
tft.drawHorizontalLine(50,50,50,GREEN);
tft.drawHorizontalLine(50,100,50,GREEN);
tft.drawVerticalLine(50,50,50,GREEN);
tft.drawVerticalLine(100,50,50,GREEN);
void testFillRoundRect() {
for (uint16_t x=tft.width(); x > 20 ; x-=6) {
tft.fillRoundRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, x/8, tft.Color565(0, x, 0));
void testRoundRect() {
for (uint16_t x=0; x < tft.width(); x+=6) {
tft.drawRoundRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, x/8, tft.Color565(x, 0, 0));
void testtriangles() {
for (uint16_t i=0; i<tft.width()/2; i+=5) {
tft.drawTriangle(tft.width()/2, tft.height()/2-i,
tft.width()/2-i, tft.height()/2+i,
tft.width()/2+i, tft.height()/2+i, tft.Color565(0, 0, i));
void testfilltriangles() {
for (uint16_t i=tft.width()/2; i>10; i-=5) {
tft.fillTriangle(tft.width()/2, tft.height()/2-i,
tft.Color565(0, i, i));
tft.width()/2+i, tft.height()/2+i, tft.Color565(i, i, 0));
void testtext(uint16_t color) {
tft.setCursor(0, 20);
tft.setTextColor(color);
tft.setTextSize(1);
tft.println("Hello World!");
tft.setTextSize(2);
tft.println(1234.56);
tft.setTextSize(3);
tft.println(0xDEADBEEF, HEX);
void testfillcircles(uint8_t radius, uint16_t color) {
for (uint16_t x=radius; x < tft.width(); x+=radius2) {
for (uint16_t y=radius; y < tft.height(); y+=radius
2) {
tft.fillCircle(x, y, radius, color);
void testdrawcircles(uint8_t radius, uint16_t color) {
for (uint16_t x=0; x < tft.width()+radius; x+=radius2) {
for (uint16_t y=0; y < tft.height()+radius; y+=radius
2) {
tft.drawCircle(x, y, radius, color);
void testfillrects(uint16_t color1, uint16_t color2) {
for (uint16_t x=tft.width()-1; x > 6; x-=6) {
//Serial.println(x, DEC);
tft.fillRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color1);
tft.drawRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color2);
void testdrawrects(uint16_t color) {
tft.drawRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color);
void testfastlines(uint16_t color1, uint16_t color2) {
for (uint16_t y=0; y < tft.height(); y+=5) {
tft.drawHorizontalLine(0, y, tft.width(), color1);
for (uint16_t x=0; x < tft.width(); x+=5) {
tft.drawVerticalLine(x, 0, tft.height(), color2);
void testlines(uint16_t color) {
tft.drawLine(0, 0, x, tft.height()-1, color);
for (uint16_t y=0; y < tft.height(); y+=6) {
tft.drawLine(0, 0, tft.width()-1, y, color);
tft.drawLine(tft.width()-1, 0, x, tft.height()-1, color);
tft.drawLine(tft.width()-1, 0, 0, y, color);
tft.drawLine(0, tft.height()-1, x, 0, color);
tft.drawLine(0, tft.height()-1, tft.width()-1, y, color);
tft.drawLine(tft.width()-1, tft.height()-1, x, 0, color);
tft.drawLine(tft.width()-1, tft.height()-1, 0, y, color);
void testBars() {
uint16_t i,j;
for(i=0; i < tft.height(); i++)
for(j=0; j < tft.width(); j++)
if(i>279) tft.writeData(WHITE);
else if(i>239) tft.writeData(BLUE);
else if(i>199) tft.writeData(GREEN);
else if(i>159) tft.writeData(CYAN);
else if(i>119) tft.writeData(RED);
else if(i>79) tft.writeData(MAGENTA);
else if(i>39) tft.writeData(YELLOW);
else tft.writeData(BLACK);
