PieterP:
Post exactly what you want to do, and the code you have right now, without the hysteresis.
Posting working code is not really useful. Post the code that doesn't work, as well as the entire error message.
i have try to duplicate the hysteries and the analog inputs and change from A0 to A1 but its not working
its possible to integrate this code with your code ?
#include <MIDI_Controller.h> // Include the library
// Create 2 instances of 'AnalogMultiplex' with the output pins of the multiplexers connected to
// analog input pin A0 and A1 respectively, and the address pins connected to pins 2, 3 and 4.
AnalogMultiplex multiplexers[] = {
{A0, { 2, 3, 4, 5 } },
{A1, { 2, 3, 4, 5 } },
{A2, { 2, 3, 4, 5 } },
{A3, { 2, 3, 4, 5 } },
{A4, { 2, 3, 4, 5 } },
{A5, { 2, 3, 4, 5 } },
{A6, { 2, 3, 4, 5 } },
{A7, { 2, 3, 4, 5 } },
{A8, { 2, 3, 4, 5 } },
{A9, { 2, 3, 4, 5 } },
{A10, { 2, 3, 4, 5 } },
// Create 16 new instances of the class 'Analog', on the 16 pins of the multiplexers,
// that send MIDI messages with controller 7 (channel volume) on channels 1 - 16
Analog potentiometers[] = {
{multiplexers[0].pin(0), MIDI_CC::Channel_Volume, 1},
{multiplexers[0].pin(1), MIDI_CC::Channel_Volume, 2},
{multiplexers[0].pin(2), MIDI_CC::Channel_Volume, 3},
{multiplexers[0].pin(3), MIDI_CC::Channel_Volume, 4},
{multiplexers[0].pin(4), MIDI_CC::Channel_Volume, 5},
{multiplexers[0].pin(5), MIDI_CC::Channel_Volume, 6},
{multiplexers[0].pin(6), MIDI_CC::Channel_Volume, 7},
{multiplexers[0].pin(7), MIDI_CC::Channel_Volume, 8},
{multiplexers[0].pin(8), MIDI_CC::Channel_Volume, 9},
{multiplexers[0].pin(9), MIDI_CC::Channel_Volume, 10},
{multiplexers[0].pin(10), MIDI_CC::Channel_Volume, 11},
{multiplexers[0].pin(11), MIDI_CC::Channel_Volume, 12},
{multiplexers[0].pin(12), MIDI_CC::Channel_Volume, 13},
{multiplexers[0].pin(13), MIDI_CC::Channel_Volume, 14},
{multiplexers[0].pin(14), MIDI_CC::Channel_Volume, 15},
{multiplexers[0].pin(15), MIDI_CC::Channel_Volume, 16},
{multiplexers[1].pin(0), MIDI_CC::General_Purpose_Controller_1, 1},
{multiplexers[1].pin(1), MIDI_CC::General_Purpose_Controller_1, 2},
{multiplexers[1].pin(2), MIDI_CC::General_Purpose_Controller_1, 3},
{multiplexers[1].pin(3), MIDI_CC::General_Purpose_Controller_1, 4},
{multiplexers[1].pin(4), MIDI_CC::General_Purpose_Controller_1, 5},
{multiplexers[1].pin(5), MIDI_CC::General_Purpose_Controller_1, 6},
{multiplexers[1].pin(6), MIDI_CC::General_Purpose_Controller_1, 7},
{multiplexers[1].pin(7), MIDI_CC::General_Purpose_Controller_1, 8},
{multiplexers[1].pin(8), MIDI_CC::General_Purpose_Controller_1, 9},
{multiplexers[1].pin(9), MIDI_CC::General_Purpose_Controller_1, 10},
{multiplexers[1].pin(10), MIDI_CC::General_Purpose_Controller_1, 11},
{multiplexers[1].pin(11), MIDI_CC::General_Purpose_Controller_1, 12},
{multiplexers[1].pin(12), MIDI_CC::General_Purpose_Controller_1, 13},
{multiplexers[1].pin(13), MIDI_CC::General_Purpose_Controller_1, 14},
{multiplexers[1].pin(14), MIDI_CC::General_Purpose_Controller_1, 15},
{multiplexers[1].pin(15), MIDI_CC::General_Purpose_Controller_1, 16},
{multiplexers[2].pin(0), MIDI_CC::General_Purpose_Controller_2, 1},
{multiplexers[2].pin(1), MIDI_CC::General_Purpose_Controller_2, 2},
{multiplexers[2].pin(2), MIDI_CC::General_Purpose_Controller_2, 3},
{multiplexers[2].pin(3), MIDI_CC::General_Purpose_Controller_2, 4},
{multiplexers[2].pin(4), MIDI_CC::General_Purpose_Controller_2, 5},
{multiplexers[2].pin(5), MIDI_CC::General_Purpose_Controller_2, 6},
{multiplexers[2].pin(6), MIDI_CC::General_Purpose_Controller_2, 7},
{multiplexers[2].pin(7), MIDI_CC::General_Purpose_Controller_2, 8},
{multiplexers[2].pin(8), MIDI_CC::General_Purpose_Controller_2, 9},
{multiplexers[2].pin(9), MIDI_CC::General_Purpose_Controller_2, 10},
{multiplexers[2].pin(10), MIDI_CC::General_Purpose_Controller_2, 11},
{multiplexers[2].pin(11), MIDI_CC::General_Purpose_Controller_2, 12},
{multiplexers[2].pin(12), MIDI_CC::General_Purpose_Controller_2, 13},
{multiplexers[2].pin(13), MIDI_CC::General_Purpose_Controller_2, 14},
{multiplexers[2].pin(14), MIDI_CC::General_Purpose_Controller_2, 15},
{multiplexers[2].pin(15), MIDI_CC::General_Purpose_Controller_2, 16},
{multiplexers[3].pin(0), MIDI_CC::General_Purpose_Controller_3, 1},
{multiplexers[3].pin(1), MIDI_CC::General_Purpose_Controller_3, 2},
{multiplexers[3].pin(2), MIDI_CC::General_Purpose_Controller_3, 3},
{multiplexers[3].pin(3), MIDI_CC::General_Purpose_Controller_3, 4},
{multiplexers[3].pin(4), MIDI_CC::General_Purpose_Controller_3, 5},
{multiplexers[3].pin(5), MIDI_CC::General_Purpose_Controller_3, 6},
{multiplexers[3].pin(6), MIDI_CC::General_Purpose_Controller_3, 7},
{multiplexers[3].pin(7), MIDI_CC::General_Purpose_Controller_3, 8},
{multiplexers[3].pin(8), MIDI_CC::General_Purpose_Controller_3, 9},
{multiplexers[3].pin(9), MIDI_CC::General_Purpose_Controller_3, 10},
{multiplexers[3].pin(10), MIDI_CC::General_Purpose_Controller_3, 11},
{multiplexers[3].pin(11), MIDI_CC::General_Purpose_Controller_3, 12},
{multiplexers[3].pin(12), MIDI_CC::General_Purpose_Controller_3, 13},
{multiplexers[3].pin(13), MIDI_CC::General_Purpose_Controller_3, 14},
{multiplexers[3].pin(14), MIDI_CC::General_Purpose_Controller_3, 15},
{multiplexers[3].pin(15), MIDI_CC::General_Purpose_Controller_3, 16},
{multiplexers[4].pin(0), MIDI_CC::General_Purpose_Controller_4, 1},
{multiplexers[4].pin(1), MIDI_CC::General_Purpose_Controller_4, 2},
{multiplexers[4].pin(2), MIDI_CC::General_Purpose_Controller_4, 3},
{multiplexers[4].pin(3), MIDI_CC::General_Purpose_Controller_4, 4},
{multiplexers[4].pin(4), MIDI_CC::General_Purpose_Controller_4, 5},
{multiplexers[4].pin(5), MIDI_CC::General_Purpose_Controller_4, 6},
{multiplexers[4].pin(6), MIDI_CC::General_Purpose_Controller_4, 7},
{multiplexers[4].pin(7), MIDI_CC::General_Purpose_Controller_4, 8},
{multiplexers[4].pin(8), MIDI_CC::General_Purpose_Controller_4, 9},
{multiplexers[4].pin(9), MIDI_CC::General_Purpose_Controller_4, 10},
{multiplexers[4].pin(10), MIDI_CC::General_Purpose_Controller_4, 11},
{multiplexers[4].pin(11), MIDI_CC::General_Purpose_Controller_4, 12},
{multiplexers[4].pin(12), MIDI_CC::General_Purpose_Controller_4, 13},
{multiplexers[4].pin(13), MIDI_CC::General_Purpose_Controller_4, 14},
{multiplexers[4].pin(14), MIDI_CC::General_Purpose_Controller_4, 15},
{multiplexers[4].pin(15), MIDI_CC::General_Purpose_Controller_4, 16},
// Refresh the MIDI controller (check whether the potentiometer's input has changed since last time, if so, send the new value over MIDI)
MIDI_Controller.refresh();
void setup() {}
i need this filter on all multiplexers (potentiometers) and im realy don't know how to do it ,
i delete the code that i try because it makes me nervous reading full of red errors
thanks peter for the support
