During the quarantine/riot and trash our monuments season of 2020, I decided to go on the trip around the Okefenokee Swamp (in south Georgia, USA) on my solar powered 1kW bike. I always wanted to see the beautiful birds and wildlife around the area. This is my chance.
I want to see the incoming/outgoing current and battery voltage on the 128x128 RGB OLED SSD_1351 display. I got the code working on a smaller display (.92 ssd_1306 I2C) but when I went with a bigger screen (128x128 RGB ssd_1351 SPI) same code would not work anymore. The refresh/redrawing of the graphs causes the flickering effect. I am told that Adafruit display library code is supposed to clear only the new information and leave old information such as graph axis without changes thus reducing flicker.
Please help or at least point me to a right direction- I promise to name a bird after you!
PS. Below is an approximation of what I want to see on my screen.
// This program is for drawing a chart and moving dots (illusion of moving wave) to display voltages or current levels
// Arduino UNO and SSD1351 128X128 RGB OLED display
// 6/17/2020
// Screen dimensions
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 128
// You can use any (4 or) 5 pins
#define SCLK_PIN 13
#define MOSI_PIN 11
#define DC_PIN 9
#define CS_PIN 8
#define RST_PIN 7
// Color definitions
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
#include <SPI.h>
#include <Wire.h>
#include "SPI.h" // YT Includes library for SPI communication of display
#include <Adafruit_GFX.h> //Includes core graphics library
#include <Adafruit_SSD1351.h> //Includes hardware specific library
//Library declaration
Adafruit_SSD1351 display = Adafruit_SSD1351(SCREEN_WIDTH, SCREEN_HEIGHT, &SPI, CS_PIN, DC_PIN, RST_PIN);
byte count;
byte sensorArray[128];
byte drawHeight;
char filled = 'D'; //decide either filled or dot display (F or D = dot, any else filled)
char drawDirection = 'R'; //decide drawing direction, from right or from left (L=from left to right, any else from right to left)
char slope = 'W'; //slope colour of filled mode white or black slope (W=white, any else black. Well, white is blue in this dispay but you get the point)
void setup(void)
//Serial.print("InSETUP");
display.begin();
display.fillScreen(0x0000); // This clears entire screen (BLACK)
//This section puts moving dots on chart (voltage or current levels)
drawHeight = map(analogRead(A0), 0, 1023, 4, 64 ); // 0Min/1023Max (on chart), 4Min/64Max (limits of moving dots)
sensorArray[0] = drawHeight; //vertical limit of moving dots
for (count = 1; count <= 80; count++ ) //80 Position of moving chart start
if (filled == 'D' || filled == 'd')
if (drawDirection == 'L' || drawDirection == 'l')
display.drawPixel(count, 64 - sensorArray[count - 1], BLUE); // BLACK,BLUE,RED,GREEN,CYAN,MAGENTA,YELLOW,WHITE
else //else, draw dots from right to left
display.drawPixel(80 - count, 64 - sensorArray[count - 1], CYAN); // <--- active BLACK,BLUE,RED,GREEN,CYAN,MAGENTA,YELLOW,WHITE
if (slope == 'W' || slope == 'w')
display.drawLine(count, 64, count, 64 - sensorArray[count - 1], WHITE); // BLACK,BLUE,RED,GREEN,CYAN,MAGENTA,YELLOW,WHITE
display.drawLine(count, 1, count, 64 - sensorArray[count - 1], WHITE);
display.drawLine(80 - count, 64, 80 - count, 64 - sensorArray[count - 1], WHITE); // BLACK,BLUE,RED,GREEN,CYAN,MAGENTA,YELLOW,WHITE
display.drawLine(80 - count, 1, 80 - count, 64 - sensorArray[count - 1], WHITE);
draw_Chart_Axis(); //Draws chart borders & tickmarks
//********* PROBLEM AREA PROBLEM AREA PROBLEM AREA
//display.display(); //exit status 1 'class Adafruit_SSD1351' has no member named 'display'
//display.clearDisplay(); //error: 'class Adafruit_SSD1351' has no member named 'clearDisplay'; did you mean 'invertDisplay'?
//display.display(); //needed before anything is displayed.. from <Adafruit_SSD1306.h> library //this works on smaller OLED
//display.clearDisplay(); //clear before new drawing.. from <Adafruit_SSD1306.h> library //this works on smaller OLED
/* Clearing the entire display causes flickering.
This is why the Adafruit library has less flicker.
The Adafruit library doesn't clear areas that have not changed,
it rewrites these areas with the same data.
If you selectively rewrite only areas that are modified there will be less flickering.-
Bill Greiman fat16lib@sbcglobal.net
//----- trying to "clear" screen without causing graph to flicker --------
//tft.fillScreen(0x0000); //Attempt 1: blacks out graph...still flickers
//tft.fillRect(0, 0, 128, 128, BLACK); //Attempts2: blacks out graph...still flickers
for (count = 80; count >= 2; count--) // count down from 160 to 2
sensorArray[count - 1] = sensorArray[count - 2];
void draw_Chart_Axis() // Draws chart axis.
display.setCursor(90, 0); // changing all display. to tft.
display.setTextSize(1);
display.setTextColor(WHITE); // BLACK,BLUE,RED,GREEN,CYAN,MAGENTA,YELLOW,WHITE
display.print(drawHeight-4); // Numerical value
display.setCursor(90, 8);
display.print("KM/h"); // Label will change to volts
display.drawLine( 0, 0, 0, 60, WHITE); // 64//32 ); // Left Vert line on graph Horiz/Vertical
display.drawLine(80, 0, 80, 60, WHITE); // 64//32 ); // Right Vert line on graph
for (count = 0; count < 70; count += 10) //40-> 60 //Number of horiz marks
display.drawLine(80, count, 75, count, WHITE); //Length / Position of RIGHT horiz marks,
display.drawLine( 5, count, 0, count, WHITE); //Length / Position of LEFT horiz marks,
for (count = 10; count < 80; count += 10) //80 Num of Horiz Pixels
display.drawPixel(count, 0 , WHITE); // Horizontal dots on graph
display.drawPixel(count, 30 , WHITE); //30
display.drawPixel(count, 60 , WHITE); //60
