hi all
i try to make flip flop as:
1 input set the output
1 input reset the output
when i lern plc it's call d flipflop
any one can to it?
tanks
hi all
any one can to it?
tanks
Do you mean a hardware FF (in which case just go buy one) or to replicate that function in software?
Rob
There are lots of different types of flip flop:-
This is not a homework assignment is it?
@robi201 - if you have more questions I suggest you post them here.
set/reset, to start motor via input when press button the motor start, and next button stop the motor
tamks
Refer to reply #1.
Rob
Is this for a regular start stop setup with a relay? Like press start and run until stop? Basically you have the no contact refeed after the start switch so it latches, probably the most direct way
if its with transistors I imagine it can work the same way you need two transistors,
or a 555 timer can be set up to work this way, or an actual flip flop ic
or in software
