flipping orientation on tft_320qvt_9341 3.2 inch touchscreen
Hi, former lurker here. I'm trying to figure out how to rotate the orientation of this display by 180 degrees. I'm using an Arduino Mega 2560 R3, and I want the orientation to be such that the usb port is on the bottom right. My research has led me to believe that I most likely need to change some number in the ILI9341 initlcd.h file, assuming ILI9341 is the correct driver for the screen, but I've seen else where that it is SSD1289? I've seen a similar thread posted here but they were all for different drivers and I couldn't figure out how to map those changes to this one. I'm also assuming it's the 16 bit case, not sure how to find that out.
Anyway, I can't find any information on what line to change for this particular driver, I was hoping someone could help me out. Any information would be much appreciated. All this stuff is kind of gibberish to me. If there's a simpler way to do this please share. I'm using URtouch and UTFT libraries btw.
initlcd.h
case ILI9341_16:
    LCD_Write_COM(0xCB);
    LCD_Write_DATA(0x39);
    LCD_Write_DATA(0x2C);
    LCD_Write_DATA(0x00);
    LCD_Write_DATA(0x34);
    LCD_Write_DATA(0x02);
    LCD_Write_COM(0xCF);
    LCD_Write_DATA(0XC1);
    LCD_Write_DATA(0X30);
    LCD_Write_COM(0xE8);
    LCD_Write_DATA(0x85);
    LCD_Write_DATA(0x78);
    LCD_Write_COM(0xEA);
    LCD_Write_COM(0xED);
    LCD_Write_DATA(0x64);
    LCD_Write_DATA(0x03);
    LCD_Write_DATA(0X12);
    LCD_Write_DATA(0X81);
    LCD_Write_COM(0xF7);
    LCD_Write_DATA(0x20);
    LCD_Write_COM(0xC0);    //Power control
    LCD_Write_DATA(0x23);   //VRH[5:0]
    LCD_Write_COM(0xC1);    //Power control
    LCD_Write_DATA(0x10);   //SAP[2:0];BT[3:0]
    LCD_Write_COM(0xC5);    //VCM control
    LCD_Write_DATA(0x3e);   //Contrast
    LCD_Write_DATA(0x28);
    LCD_Write_COM(0xC7);    //VCM control2
    LCD_Write_DATA(0x86);   //--
    LCD_Write_COM(0x36);    // Memory Access Control
    LCD_Write_DATA(0x48);
    LCD_Write_COM(0x3A);
    LCD_Write_DATA(0x55);
    LCD_Write_COM(0xB1);
    LCD_Write_DATA(0x18);
    LCD_Write_COM(0xB6);    // Display Function Control
    LCD_Write_DATA(0x08);
    LCD_Write_DATA(0x82);
    LCD_Write_DATA(0x27);
    LCD_Write_COM(0xF2);    // 3Gamma Function Disable
    LCD_Write_COM(0x26);    //Gamma curve selected
    LCD_Write_DATA(0x01);
    LCD_Write_COM(0xE0);    //Set Gamma
    LCD_Write_DATA(0x0F);
    LCD_Write_DATA(0x31);
    LCD_Write_DATA(0x2B);
    LCD_Write_DATA(0x0C);
    LCD_Write_DATA(0x0E);
    LCD_Write_DATA(0x4E);
    LCD_Write_DATA(0xF1);
    LCD_Write_DATA(0x37);
    LCD_Write_DATA(0x07);
    LCD_Write_DATA(0x09);
    LCD_Write_COM(0XE1);    //Set Gamma
    LCD_Write_DATA(0x14);
    LCD_Write_DATA(0x11);
    LCD_Write_DATA(0xC1);
    LCD_Write_DATA(0x36);
    LCD_Write_COM(0x11);    //Exit Sleep
    delay(120);
    LCD_Write_COM(0x29);    //Display on
    LCD_Write_COM(0x2c);
Go on. The TFT_320QVT will contain SSD1289. The ILI9341 screen will be printed TFT_320QVT_9341.
There are two ways to change directions either
    LCD_Write_DATA(0x48 ^ 0xC0); //invert MY, MX
or
    LCD_Write_DATA(0x82 ^ 0x60);  // invert GS, SS
Do one or the other. Not both.
David.
Wow thank you. Worked like a charm. I've been spending hours on this and here you are fixing my problem in less than 10 minutes. Thank you!!
